Like Tree2Likes
Go-Tech Engines Thread
Old 04-09-2008 | 05:19 PM
  #2266
mugenb46's Avatar
Originally Posted by superdave2
these are the engines that losi makes right????????
Losi !!! no
GO Engines CO LTD makes them Distributed in the US by Racefactor Ind.
mugenb46 is offline
Old 04-09-2008 | 06:39 PM
  #2267
Vigilante212's Avatar
Losi doesnt make any engines in fact. They get all of thier engines from other companies.
Vigilante212 is offline
Old 04-09-2008 | 07:32 PM
  #2268
A.C's Avatar
A.C
i have a .28 with dynamite 086 pipe,
.21 5port with JP3.
can anyone tell if this set up is ok? or it can be better.
pls advice.
A.C is offline
Old 04-09-2008 | 07:37 PM
  #2269
Originally Posted by aznitronut
Thanks for the feedback on the pipe tmizzle, I'll have to give it a try. This .25 has been a real pain breaking in, temps to high, rarely under 250, and if it is, no power, notice carb had air leak, and bottom o-ring in case for carb was a little fuzzy, I don't get that, I never had the carb out of it, sealed the carb, but have not tried since then, around a half plus or so fuel thru it. This is my 3rd Go engine, I have the 5 port and the 7 port motors already.
Tony, I didn't know you were Go guy. I thought it was all RB fpr you? LOL
Colin
C Branch is offline
Old 04-09-2008 | 07:47 PM
  #2270
chad220's Avatar
Hey guys im haveing a little trouble mounting up my new 5pt on my 8ight. it seems like i cant get any play on the clutchbell. Do i need to dump the GO collet and get a losi collet to get the correct spaceing?
chad220 is offline
Old 04-09-2008 | 09:04 PM
  #2271
mugenb46's Avatar
Yes use the losi collet, you may need the thick washer as well, get the flywheel collet for the xxx nt it has the correct collet and washer.
mugenb46 is offline
Old 04-09-2008 | 09:19 PM
  #2272
22Racer's Avatar
Yes, I run Losi's and you need to use the Losi collet or a .12 size collet. I have to run a washer between the engine and collet also.
Rex
22Racer is offline
Old 04-09-2008 | 09:43 PM
  #2273
aznitronut's Avatar
Colin, I've ran the Go .21 in my truggy for a long time, then it dumped on me, and I had a hard time getting it tuned in, so when Russell and I went to the Silverstate, I got a .25 from him to run at the Silverstate, but never got it broke in in time, it's in my other truggy that my son is racing at the truck nats in a couple of weeks, maybe I get get it ready for him to run.
aznitronut is offline
Old 04-10-2008 | 03:39 AM
  #2274
chad220's Avatar
ok thanks guys , apprecaite the info. Whats the best way to get that thing off there?
chad220 is offline
Old 04-10-2008 | 05:01 AM
  #2275
jnc011994's Avatar
Default noobie question
Hello guys,
Just got my GO Engine and break in was done by the tech in our LHS. Just have a quick question, How do i know if i have the Go .21 7Port is a Gen2 or Gen4? after reading all 18 pages, it was said that it has a Composite Carb. First of how do i know if its a composite carb? Sorry total noob with these things.
Thanks,
Jojo
jnc011994 is offline
Old 04-10-2008 | 12:33 PM
  #2276
I will be running Go engines this year and I have a couple of questions. Which heads fit these engines? Add the extra shim for break in? Do they still need to be sealed up like the old ones?
Thanks,
Colin
C Branch is offline
Old 04-10-2008 | 02:04 PM
  #2277
grizz1's Avatar
Hi Colin, Not sure on the heads, but I am sure one of the tech wizards on this thread will be able to help you there.
Use the break in shim for sure - especially on the 5 and 7 Ports. I believe the new 3 Port Race is not quite as tight. I have broken in two 5 Ports and the shim makes it sooooo much easier to start and initially tune. Leave the shim in for around 20 tanks or so. You will feel when the motor loosens up some.
Doesn't hurt to seal the motors up. Back plate, pinch bolt ends and around the carb neck
grizz1 is offline
Old 04-10-2008 | 02:10 PM
  #2278
TMizzle's Avatar
any Nova/RB head will fit.
The new heads from GO look pretty sweet. i was never a big fan of the GO logo with the tire. The new logo looks great.
to see the new heads go to www.go-engine.com
TMizzle is offline
Old 04-10-2008 | 03:24 PM
  #2279
You can shave a little bit off the thick end of the collet until you get the desired spacing.
Old 04-10-2008 | 08:08 PM
  #2280
jgtruggy's Avatar
Hey it's me with .25 6port. I got through two tanks of break through but I couldn't find an idle. Had to mess with the needles just to get a good temp. I know every mill is different no matter what manufacture. The needles are a rough estimate in settings. When I finish my break in what is the highest temp I should see (on the box still)? Thanks for the input.
jgtruggy is offline
