Like Tree2Likes
Go-Tech Engines Thread
Old 10-04-2007 | 04:43 PM
  #211
Swede#1's Avatar
I have the 5 port. I just noticed something else when i was browsing for bearings, it says 6mm for the front bearing on the parts list and on A-main, but i measured my crank and its 7mm ?? I also noticed that on the pictures it looks like there is a seal on both sides of the bearings, but on the ones in my engine there is only one on one side on the front bearing and none on the rear ? is that just something to protect them ?
Swede#1 is offline
Old 10-04-2007 | 05:10 PM
  #212
MassiveMods's Avatar
The 6 MM measurement is for the thickness of the bearing not the inner Diameter. And yes its common they come with 2 seals , just pick the inner one off so that you have one seal on the outside .
Cheers MM
MassiveMods is offline
Old 10-06-2007 | 04:05 PM
  #213
What's the stock shims for the 5 port turbo and normal heads?
magbarn is offline
Old 10-07-2007 | 11:26 AM
  #214
rossoh10's Avatar
I have a question.Now that its starting to get cold.I have been fouling or burning my plugs.When I run during the day when the temps are warmer I don`t have this problem,but as the night carries on I end up having to change my plug.The engine doesn`t flame out,it will go the whole race,but when its time to fire it up for the next race my plug is dead.What am I doing wrong.I`m running a Go 5port with a os 2060 and byrons 30%.There is only 1 1/2 gallons on the engine.I am also running a OS #8.I have always ran this plug in every engine I have owend and haven`t had a problem.Some of the guys at the track think I`m running my LSN a little lean,but then again during warmer time of the day I don`t foul plugs
Any thoughts and suggestions will be much appreciated
rossoh10 is offline
Old 10-07-2007 | 11:34 AM
  #215
air8's Avatar
When the temps start to drop for the day the air/fuel mixture does start to lean out. The air is more dense when the air is cooler. Therefore more O2 per parts fuel. Just richen the needles slightly (few hours) till you find the sweet spot. Gotta do the same thing here. Temps will fluctuate by 10-15 degrees on normal days. From sun high to ten o'clock at night.
air8 is offline
Old 10-07-2007 | 06:05 PM
  #216
got my gotech 5 port turbo assembled fly wheel and clutch but this thing is extremely hard to turn over no plug in and barely turn by hand how will it ever start and run? My starter box won't turn it over!Thanks Lance
lance is offline
Old 10-07-2007 | 06:12 PM
  #217
rossoh10's Avatar
I had the same porblem.You need to usea heat gum and heat it up to 200 degress and then try to start it
rossoh10 is offline
Old 10-07-2007 | 08:30 PM
  #218
Jason Halvorson's Avatar
Lance, i see you picked up one of these go tech engines ive been talking about...we missed you at the last race, i figured you were busy farming...if you need any help with your new motor give me a call, ill pm you my phone number...
Jason Halvorson is offline
Old 10-08-2007 | 05:11 AM
  #219
I have a Go 7 port with a King Headz cooling head and Novarossi carb for sale here. Less than 3/4 gallon on it. With 053 Werks pipe for $150 shipped if anyone's interested pm me. Thanks.
cwalters is offline
Old 10-12-2007 | 01:04 PM
  #220
g26er is offline
Old 10-12-2007 | 09:08 PM
  #221
kamlooper's Avatar
Yes! The word on it is a very good engine for a "sport". At least an OS VG equivalent. Im gettin one for backup.
kamlooper is offline
Old 10-14-2007 | 01:10 AM
  #222
has anyone had replies from the email on GO Tech web pages when they sent a email?? i sent one a 5days ago or so and havent heard from them.
DirtRacer is offline
Old 10-14-2007 | 01:27 AM
  #223
nazprerunner's Avatar
Default 3 port go motor
yes the 3 port motor is really good i watched russell run that motor awhile back the motor has the power of the 5 port just not the top end.
nazprerunner is offline
Old 10-14-2007 | 05:41 AM
  #224
Where can I buy just the piston and sleeve for the 5 port. I don't need a piston/sleeve/rod as sold by Carolina's rc. I have a new rod.
satoch is offline
Old 10-14-2007 | 09:34 AM
  #225
Rocket42's Avatar
Satoch, the piston and sleeve only is no longer available in the U.S., it was my call to only sell the piston sleeve and rod assemblies, its much cheaper to buy it as a kit then just the piston and sleeve assembly and plus it is always a good thing to have a fresh rod and wrist pin assembly to throw in your engine every 3-4 gallons as reccomended.
If I get requests to bring back the Piston and Sleeve assembly only, I will do so.
The 3port engine is very good, I would say its the new O.S. rg, It is a sport engine so it doesn't use the highest quality materials like the race engines, but still makes a great backup or practice engine I wouldn't have any problems racing it again either. Plus the turbo head button fits it fine which really helps with the performance.
Rocket42 is offline
