Like Tree2Likes
Go-Tech Engines Thread
Old 02-17-2008 | 06:33 PM
  #1696
GenReaper's Avatar
pwnzor you have PM.
A nice little essay on all of these motors.
For your eyes only tho.
GenReaper is offline
Old 02-17-2008 | 07:10 PM
  #1697
mugenb46's Avatar
congrates to Chris Pace and Justin Dyers on the great a main finish at motorama this weekend.
mugenb46 is offline
Old 02-17-2008 | 07:14 PM
  #1698
hansarvin's Avatar
Trevor good to see that you took my advice and are looking at the Go's, good call bro. Mine's sitting at the post office right now waiting for me to pick it up!
hansarvin is offline
Old 02-17-2008 | 07:23 PM
  #1699
I didnt get to make the A main my car had problems all weekend but the engine ran get I was just as fast and the top drivers just didnt have the luck.Seems like I found the only rock on the track to get stuck in my flywheel and get me to cut off but I still finished.
JustinD is offline
Old 02-17-2008 | 08:18 PM
  #1700
mugenb46's Avatar
Oh ok, phill sanders called to tell me about his .25 rockin all weekend and said you along with chris where doing good, he had said you were in it, good job though, I've had that kind of luck, but much more breakege
mugenb46 is offline
Old 02-17-2008 | 11:50 PM
  #1701
I can not decide on which engine for my Losi 8ight-T can someone please help?
gewaun is offline
Old 02-18-2008 | 05:50 AM
  #1702
I would get the Go 5 port .21 Turbo its a beast.
JustinD is offline
Old 02-18-2008 | 07:00 AM
  #1703
mugenb46's Avatar
Or the .25 it a beast thats in a bad mood LOL
mugenb46 is offline
Old 02-18-2008 | 07:34 AM
  #1704
Does the .25 durn as much nitro as the .28 so noticeable that I should stick with a .21? One more question should I go for turbo or standard plug.
gewaun is offline
Old 02-18-2008 | 07:37 AM
  #1705
mugenb46's Avatar
the .25 vand .28 have no turbo yet, the .28 may burn more and the .25 gets as good as a .21, the 25 is turning out to be the alternative to a .28, i have seen them in action, i have one going in my truggy.
mugenb46 is offline
Old 02-18-2008 | 09:34 AM
  #1706
will g's Avatar
im breaking in .25 go now for nitro challenge and man that motor has tons of power im on my 10th total tank and not letting it get over 220 ish and it has tons of power and im not even full throttle yet how much more should i run to insure its broke in enough to poss run 7 mins thnx will g
will g is offline
Old 02-18-2008 | 09:39 AM
  #1707
I finally have everything for my Jammin X1-CR except an engine. Being that I am just starting out in nitro I figured to get something cheap that someone pulled from an RTR car and run it until it died on me. However, I am also looking at the OS $150 engine (.21VG) but was wondering if maybe I should just pony up the extra $50 for the Go tech?
the track that I would be on in the winter is really tight and small, but the summer track seems to be quite a bit larger. if anyone knows the Medina R/C track just south of Cleveland, that is the one I am speaking of.
Anyway, if I monitored temps as I should, ran 30% fuel, and heated up the engine before running, is there any reason that I should be worried about destroying it? (a Go-Tech) Also, which would you guys recommend for a Jammin buggy? I was originally just going to go with teh Go 3 port standard version, but the 5 port and 7 port seem like they should run a lot better. Is there a newer 3 port that I should look at? Any help would be appreciated.
MikeInCtown is offline
Old 02-18-2008 | 09:40 AM
  #1708
mugenb46's Avatar
i don't start looking at runtimes intill breakin and full seating is over, normally about a gallon of running with easy race tune.
mugenb46 is offline
Old 02-18-2008 | 09:48 AM
  #1709
Brandon Melton's Avatar
Just to let you guys know, Chris ran my 5 port this weekend that has about 2 gallons on it, and after a warm up lap, 5 minute heat, and the cool down lap, he was coming back with half of a tank left, very impressive. He could have pitted at the 10 minute mark but with this race being 45 minutes it was not beneficial to push it.
He was leading when something caused it to flame over the big jump upon landing, which was the first flame that motor has ever seen. It may have been caused by something getting into the flywheel upon the flat landing.
Brandon Melton is offline
  #1710
mugenb46's Avatar
Are the tracks indoor and outdoor med bite or high or loamy, GO has a new Race Spec 3 port, it's a good motor. I'm running it know, but if you think more bottom is needed or thats what you like the 5 port is the ticket, if you like smooth linier bottom the 3 and 7 ports are good for that style, the 7 port will have more top than any of them, which it's hard using all the top it puts out, so i always recommend the 3 or 5 for buggy, but if your tracks are loose and loamy, the 7 is very smooth like the 3. An 053 is good on the 7 ports, and a 086, 2047, 053 works good on the 3 and 5. Hope this helps
mugenb46 is offline
