Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Small cut in front bearing seal? >
Like Tree6Likes
  • 1 Post By petersen114
  • 1 Post By Roelof
  • 1 Post By briefer
  • 2 Post By briefer
Old 07-27-2023 | 02:46 PM
Default Small cut in front bearing seal?
Is this ok? I have a small cut in the blue seal of my novarossi 17011 front bearing. no idea how it got there!
I dont have any leakage or anything. I just dont know if
it could have an air leak? Could a small cut in the seal affect tune or operation?
nitro coffee is offline
Old 07-29-2023 | 03:40 PM
petersen114's Avatar
If it worry’s you then remove the seal then clean it really good with some rubbing alcohol then ad some high temp RTV. I’ve had to do it before for a bearing shield that kept popping off.
nitro coffee likes this.
petersen114 is offline
Old 07-31-2023 | 03:20 AM
briefer's Avatar
Just change the seal.
briefer is offline
Old 07-31-2023 | 03:43 AM
Roelof's Avatar
Oh, can you give a link to only a seal fitting that bearing?
It is wrong to say/think the seal is airtight, that for sure it is not. The seal is only to keep the grease better in and the dust better out.
Inside the engine with the groove in the crankshaft and a small channel between carburator and front bearing does give a kind of seal.
Roelof is offline
Old 07-31-2023 | 06:49 AM
briefer's Avatar
you just made a seal cry
briefer is offline
Old 07-31-2023 | 08:52 AM
Maybe this Seal will make yours feel better.
Old 08-01-2023 | 12:57 AM
briefer's Avatar
my SEAL wins!
petersen114 and nitro coffee like this.
briefer is offline
Old 08-01-2023 | 05:45 AM
my SEAL wins!
a whole ton of yes, ya this one, yes yes
Old 08-02-2023 | 10:25 AM
That's not the issue or the discussion. They also never sold only the seal. That would be cool, huh
Old 08-04-2023 | 10:58 AM
briefer's Avatar
but you could use the seal of an old bearing though
briefer is offline
Old 08-05-2023 | 08:22 AM
Bsthetech's Avatar
R/C Tech Elite Member
The seals aren’t airtight. They’re just there to limit the dirt inside the bearing. Leave it as is, drive it like you stole it, then replace the bearing before next season. Avidrc.com is your friend.
Bsthetech is offline
