Seattle RC Racers/Hangar 30
#9166
I'll make my flight tomorrow if I have to shovel the damn runway myself!
#9167
Attention Xray Drivers!
Hi guys,
So, I spent a lot of time doing a scavenger hunt around the internet and stumbled upon:
Teflon Coated Shock Bodies made by a company called Atomic
They were once upon a time sold at SpeedTech, but I've never seen them in stock. So I did a little digging...
I found Atomic's site and searched through all of Atomic's distributor websites around the globe and found them for sale in Spain of all places. Anyway, they cost about $40 US for a set of 4, plus about $10 US for shipping.
I wanted to share the wealth, so here is a link for those interested in upgrading their Xray shocks:
http://www.technicalrp.com/catalog/a...e-p-39096.html
Peace,
Samwise
Peace,
Samwise
#9168
Hi guys,
Peace,
Samwise
Peace,
Samwise
#9169
Good point, Peter, good point. But it was fun doing the scavenger hunt nonetheless
Tamiya shocks are pretty awesome. Sam feels a little silly now I guess I'm a sucker for the adjustable pistons, I just think they're cool
Anyway... see you guys on Wednesday!
Peace,
Sam
#9170
I have used the Atomic teflon coated aluminum shock bodies numerous times. IMHO a very good upgrade over the stock plastic shock bodies. I found my shocks didn't require a rebuild nearly as often.
and they are an ok color too
#9171
That hilarious, gripgoat has been doing me a favor going to egr racing to get me some atomic stuff for micros (they are well known in the micro field).
http://www.egrracing.com/shop/index....fc31722de87f71
EGR is the store front for atomic. However,looks like not in stock, but maybe another shop there has? Anyhow you'll have to ask gripgoat if he can or not. $40 is still cheaper than buying a set a new Tamiya TRF if they are $60+ ?
#9172
-Mike
#9173
Modified Touring?
Hey Guys!
So, I'm curious... is anyone planning to run Mod Touring before the end of the season? If so, I have a few questions:
-What motor do you recommend?
-What number of turns (for a Mod newbie)?
-What FDR for that type of motor/number of turns?
-What (if any) ESC settings need to be changed to run said motor?
-Will that same motor/number of turns be good outdoors as well this summer?
Peace + Burnin' Rubber!
Samwise
Samwise
#9174
Everyone's having to much fun in stock at the moment I think! Closer to the ECC you will see some wanting to race Mod
Hey Guys!
-What motor do you recommend? LRP 5.0 octa with 12.5 works rotor or Reedy Sonic 5.0
-What number of turns (for a Mod newbie)? 5.0
-What FDR for that type of motor/number of turns? Around an 8.7
-What (if any) ESC settings need to be changed to run said motor? Blinky would be a good starting point. Add boost to get more top end down the straight!
-Will that same motor/number of turns be good outdoors as well this summer? Yep just add more punch and boost!!!
Samwise
Samwise
#9177
The minimum conversion would be the suspension parts, crush tubes, hub bearings and CVA axles. That stuff comes to $81 before tax.
-front arms
-rear arms
-steering blocks
-rear hubs
-caster blocks (you can use the older caster blocks if you choose)
-crush tubes
-CVA axles
-5x10 bearings
We have everything in stock beside the CVA axles. They are still backordered. The conversion does not work without the axles because a 5x10 bearing is not the same thickness as a 6x10.
-front arms
-rear arms
-steering blocks
-rear hubs
-crush tubes
-CVA axles
-5x10 bearings
#9179
Xray C Hub
Hi Sean,
If you have any in stock, could you put an Xray Hard 6-Degree Right C hub in the Tub for me?
I ordered a pair of C hubs online, but the right one was for the T2'008 and so the hole in the hub where the axle goes was too small. The left one is fine. I guess Xray changed the mold in the past 4 years haha!
Thanks Buddy,
Sam
Here is the part number:
302375
P.S. If all you have are the Medium composite ones, please bring a pair (Left and Right 6 degree). Thanks again!
Thanks Buddy,
Sam
302375
#9180
"Not 2B Nitpicking", or anything.........
And BTW, some Xray drivers think the Composite Shock bodies are just fine, and in some cases, a better choice over the alloy "Upgrade".........(case in point, Ralph Burch's 2010 IFMAR 200mm Nitro TC world championship victory in Texas July heat ! It's rumored that the plastic shock bodies are less reactive to temperature changes and the 1 hour workout that a Nitro Sedan endures in a A Main).
