Kyosho drivers of the NorthWest
#17
For us guys that will be racing the new TRCR layout, it's not at all hard but there is a washboard section of 8 going at an offset angle. Other than that a sweeper to straight back to a small sweeper before a switch back. There shouldn't have to be any setup changes that i can see. I was thinking about changing out my shock pistons from 2B to 2A just for the washboard section but not sure of what that may or may not do.
#18
Regional Moderator
Oh good washboards are a advantage to RB-5's. I'll test at the track tonight. Let you know if you need shock changes.
For the center one way you just need the bearing and one-way outdrive. The kit comes with the one-way bearing holder for the center shaft. just not the bearing and the outdrive.
Tim
Tim
#20
#22
#23
GEORGE YOU ARE A&E DRIVE THIS IS FOR THE SUPER FAST RED ARMY GUYS
NINJA
NINJA
#25
Alright you Kyosho guys hopefully you will be able to help me make a good choice. I am going to run 4-mod this comming year(NCT?) and I am having a hard time making a choice between brands. If I was going to try a Kyosho would it be better to get an SP or FS? Are there issues with either car? Any insight would be helpful! Thanks
#26
Regional Moderator
Either ways the Kyosho will be at the front again this year =).
tim
#27
i mess;in with you pat but is does have a new mp9 sweet !!!!
#28
#30
I planed on setting it up to run the 10.5 4WD ECT class, and my B44 in MOD. Haven't completly made up my mind yet.
