Team Magic G4
#7531
the g4+ was ment to be the car with all the hopups
but in the g4+ kit, the middle pulley mount and the servo mount are plastic and they do a aluminum one, and no adjustable sterring akerman so to me they are hopups
so was tm trying to say on weight and no ceramis bearings either my2cents
apart from that a great car to build
cant wait to see it on the track but
#7534
MY G4S+ died!!!!! in the entry of straight..
for too much torque... my G4S+ was sick!!
#7536
Yeah Gansei what did you hit or did someone hit you ???
That looks like a very hard hit, id suggest checking the hinge pins.
#7537
Just finished testing my 2nd G4s with the IDM Evo3 and ED at Crystal Park (southern cal) and all I can say is that this combo was insane. The engine only needed 2 tanks of idle break-in and 1 more tanks on the track and it was ready. This has to be the easiest engine to break-in, and it did not lock at tdc like the OS and Novas. The 2nd speed engagement was coming in too early so I had to button down the two screws. (BTW, I did not have to shorten the screws). This was my first time at this track, and with the car handling great, it made it very easy to learn the lines around the track. This narrow,medium size track, which held the 2006 200mm nitro nationals, was just a bit dusty and had medium traction yesterday.
This was my set-up
Front:
width 197mm
ride height: 5mm
droop: 1mm
toe out: 1 degree
camber: 1 degree
shock spring, oil, position: Aqua, kit oil, 2nd from bottom
sway bars: 90degrees
tires: GQ 42 shores, 58mm
Front one-way
Rear:
width 200
ride height: 5mm
droop: 4 mm
toe in: 2 degree
camber: 2.5
shock spring, oil, position: stock silver, kit oil, 2nd from bottom
tires: GQ 42 shores, 60mm
Diff oil: 30k
The car had excellent turn in and good on power steering. The rear end was planted but would get squirmy only when I hit a dusty patch.
After 3 tanks, my brand new steering servo (Fut 9550) started to act up. On the back straight, I let go of the throttle to get ready for the sweeper, but the steering did not work. The car crashed on the tire barriers. Luckily, there was no damage. The servo was working again, so I put the car back on the track for a couple more laps, and the steering servo would intermittently not respond. The battery was at charged and the connections were tight. So I gave the new car a rest and fired up the old one.
This was my set-up
Front:
width 197mm
ride height: 5mm
droop: 1mm
toe out: 1 degree
camber: 1 degree
Front one-way
Rear:
width 200
ride height: 5mm
droop: 4 mm
toe in: 2 degree
camber: 2.5
Diff oil: 30k
#7538
it is a fast engine, just lets see how the reliability and service life goes . i have mistreated mine due to my fuel tank issues, it was hot then it was rich , i thaught it may have been time to get a new one. but the following round with a new tank , presto it came alive.
#7539
i hit front fense corner...
i suffered from lack of rear grip...
i changed shock spring, shock oil, rear toe-in, down-stop etc on...
But i could not find lack of rear grip...
so i ranked 4th in the best lap on today... (17.157 sec)
But i find stripped front belt just now!!!!!
#7541
Rear Springs
I have just 99% assembled G4S and have query with silver factory spring for rear. I feel too hard. Is anyone racing with factory silver spring in rear? I have put in V one RRR spring in back for now as dont have Team Magic Spring Kit ??
#7543
But according to my knowledge..
rear traction is bad as more spacers under the outer rear top link..
so i tried 0~1mm spacers under the outer rear top link for rear traction..
is it wrong?
#7545
so is that 2 thumbs up for the IDM ?
At least with my trials, this engine was running at
200-210 C and did not loose the tune. To me, the car was flying, but only in a race can I really compare. I've heard other people with JL Picco had 4 gallons thru it and still running good, so ours should last a while. I'm only gonna use it for races. I have other older motors for practice. Good luck with yours!!!
