Team Magic G4
#7366
HYUNDAI NF SONATA
HYUNDAI NF SONATA TEST BODY
open car..
open car..
#7367
i am so happi to see the AVATAR display i made for the forum on your front Window
very very differant body GANSEI!!!
i tooo have ordered my parts for G4+ conversion with front flying arms and rear new sway bar
O yeah, new CRF engine on its way aswell!
shall be the first here in Adelaide tohave motor combo and new parts on G4S/G4S+ added bitz
#7368
i will do conversion My G4S to G4+.
i will get G4+ spare and option parts tomorrow.
this is my conversion list.
1. ‘Flying Wing’ Suspension Arms (front upper/low. rear sus), front knucle arm.
2. rear bulkhead,rear bulk bracket, rear Y type stebil.
3. 2nd gear, 2nd gear housing, 2-speed shoe, new clutch shoe.
i will take a picture my G4+ conversion machine in tomorrow
#7369
they ordered rear anti-roll bar,shoe,arm etc on..
so i will go TM Distributor to buy parts in afternoon.
#7371
the weight of the car isnt changing. but if you move the wheels forward or backward , then the weight balance changes. thats what i was trying to say.
the center point of the weight between the front and rear wheels is changing, so the balance is there for changing. or am i reading too much into it ?
i know i have had problems getting steering into the car of late, and the 3mm shorter rear wheel base has made that a thing of the past, so there is something in it. i wouldnt mind trying a std rear and a shorter front wheel base just to see the changes. im guessing it will give me a little more rear grip and then be chasing steering again. so there are valid points to ZOOMs statement.
#7372
I have tried the wheelbase adjustment on several different brands of cars and I find that it tightens the minimum turning radius the car is capable of and also since there is a higher % of weight on the rear there is more forward and side bite which can make the car push a bit, in which case shortening the front will balance it out but that also increases ackerman and decreases caster, so shortening the front might be counterproductive. So basically shorten the rear when there are tight radius turns and/or lower grip. I ran this way on the past two MWS parking lot tracks.
thanks..
#7373
The G4+ and all the parts have arrived in Australia - Contact your LHS to get them to contact HEI international to secure one for yourself. The team at HEI have also got all the parts to upgrade any part of your G4S to G4+ spec as well.
Pricing is very competitive compared to getting them in from overseas as well!! Ari has posted a couple of pictures to get the taste buds watering
http://www.rctech.net/forum/showpost...&postcount=149
#7374
#7376
#7378
G4+ is on the ground in Aus - I see my guy in Western Australia has them for a pretty competitive price as well. Check it out at www.rcgear.com.au.
#7379
no wide parts list for g4S, like Raceday Hobbies or RC Mart & RC Mushroom....!
keep in mind, so if there is a G4+ there, still need to back it up with a wide variety parts area to attract the new shopper or even yet the local shopper!
As i have mentioned before, i shop overseas because, we have tried to support local hobby shops, but in time they are either slack, say they cant get or just not interested in making money!
No wonder why the internet market does so well, its either a massive warehouse, or a dedicated supporter of the product!!!!
Anyways i hope it updates in time, thou its great to see the G4+ land in AUS, funny enough i have a cross breed now LOL
#7380
G4+
rear stebil is not released..
so i used v-one RRR rear stebil..
But V-one RRR rear stebil shaft's diameter is 2.2mm
G4+'s one is 2.5mm
rear bulk bracket was changed. so i mod it (cut off)
clutch shoe is some big and material was changed....
clearance could not be setup.(clearance 0mm)
so i put 3X5mm shim in clutch to make clearance.
(maybe new long bellguide washer wanted.. but it is not imported)
2nd spur gear and housing come little smaller than G4S.
2nd shoe size is not changed.. but shoe material was changed (my quess)
front wheel base can be reduced until 2mm.
rear wheel base can be reduced until 2.5mm.
front upper arm was shorten by 2mm to fit caster.
G4+'s one is 2.5mm
