Team Magic G4
Old 06-08-2007, 10:25 AM
  #7021
rcrevolution's Avatar
anyone have any setups?
gansei?
rcrevolution is offline
Old 06-08-2007, 10:35 AM
  #7022
razzor's Avatar
bud check the TM site for setup sheets and also 3hobby.net
also post info about your track and we can see what the guys advise
razzor is offline
Old 06-08-2007, 11:03 AM
  #7023
well I want a setup just to go from there, the stock TM one isnt working out too well.
Old 06-08-2007, 11:24 AM
  #7024
gansei's Avatar
gansei?
this is my recent setup for technical circuit.
width front: 197 rear: 199
front spring : mugen grey(1.8)
rear spring: serpent yellow or mugen blue or mugen dark blue
shock oil: front/rear 600-700 (kyosho) 1.2 X 2 hole
front toe out 1, rear toe-in 2.5~3.0
front camber 2.5, rear camber 3.5~4.0
front downstop 1, rear downstop 4
front diff 40000, rear diff 30000 (kyosho diff oil)
body: sturatus 3.1
shock postion: front 3th from top, rear 3th from top
rear stabil: mugen 2.3mm
front stabil: 0
tire: front/rear 37
wheelbase front 2mm cut, rear 2mm cut.. total 4mm reduced
gansei is offline
Old 06-08-2007, 12:13 PM
  #7025
rmdhawaii's Avatar
Just as a reminder, all of gansei's setups are on my Gansei Page. I'll be adding this new setup shortly.
rmdhawaii is offline
Old 06-08-2007, 12:19 PM
  #7026
razzor's Avatar
As a baseline setup id go with Brian Berry's setup from the TM site or one of Darren Johnsons(Muppetracer/Daz) from 3hobby.net or TM.
Ive been working of Darrens and its been really good for me.
Go through teh build tips as well on 3hobby.
razzor is offline
Old 06-08-2007, 12:31 PM
  #7027
wow alot of people run postive camber all around the Brian Berry setup is the first one I have seen with negative camber.
and can I get a link to the gansei page
Old 06-08-2007, 01:07 PM
  #7028
razzor's Avatar
Who runs positive camber ???
razzor is offline
Old 06-08-2007, 01:10 PM
  #7029
rmdhawaii's Avatar
...and can I get a link to the gansei page
It's in my signature on the far right.
Old 06-08-2007, 01:51 PM
  #7030
afm
afm's Avatar
nobody runs positive camber because no car can work like that, so nobody bothers to place the minus sign on the number posted as camber, it's understood they are negative figures...
afm
afm is offline
Old 06-08-2007, 07:38 PM
  #7031
so on my g4s setup sheet where it says 2 degrees camber it really means -2 degrees camber?
Old 06-08-2007, 08:34 PM
  #7032
How much is the G4+?
ioxqq is offline
Old 06-08-2007, 09:00 PM
  #7033
rmdhawaii's Avatar
No word on pricing or a release date yet.
Old 06-08-2007, 09:06 PM
  #7034
bucknuts's Avatar
Positive camber can still be seen on things like tractors or at car museums the cars of the '20s often had positive front camber.
bucknuts is offline
Old 06-09-2007, 02:34 AM
  #7035
Teehomo's Avatar
Trader Rating: 24 (100%+)
Yep - always read camber as negative. Positive camber would result in the car always loading up the outer edge of the tyre. At a minimum this would cause reduced grip as the natural inertia will increase the amount of roll to he outer edge and reduce the pressure on the inner edge. Worst case you will increase the chance of chunking tyres or increase the body roll due to sidewall movement. If you have been having handling problems and have been running positive camber then the beauty is at least you will have an easy fix to imporove things.
Teehomo is offline
