Team Magic G4
#3931
OK then iether buy the plastic part for the servo saver or put captured ball ends.Might be an idea to get the K14118 udjustable bell crank steering arm.
http://www.kfactoryracing.com/produc...4118&pageNum=2
#3932
#3933
Originally Posted by Pattojnr
thats what he was using Razzor, he stripped the plastic insert and then used one of the others, and by accident fixed his steering problems. now hows that for luck ?
you TWIT Paul....."Gascar_24" yeah i hear in final race as i was his PIT BITCH "Hey Frankie i got heaps more steering now" SOLID GOLD
#3934
OK nice story .
So the part that stripped is the plastic insert that goes into the bell crank.
2 options then ,get balls with longer threaded section so you can put a nut on the other side or captured ball ends.
Wich insert did you change too ,would be good info to take note of.
#3935
OK nice story .
by the way i thank you for the Xray link. i have the older setup book which doesnt explain the different points on the Hub adjustments for the ackerman angles. so now i know why it improved when i changed the hub point
#3936
i read about drilling piston hole to 1.2 or 1.3 mm
but i only found 1mm and 1.5mm drill. which one will be better?
1mm or 1.5mm?
thanks
1mm or 1.5mm?
thanks
#3937
Originally Posted by Toy000
quick question guys if any one can help i cant seem to get any on throttle steer its very understeery on power off power its fine the back end is sticking well
30k, 40k, maybe even 50K!! Just keep the ront end thicker than the rear.
If you use 30k rear, then use at least 50k up front so your car does not oversteer severely. If you go up to 50k at the rear, use 70k at the front. Use this last option if nothing else works. You can reduce rear toe but that will decrease rear traction when off throttle as well. If you do not want to change rear grip, then only change the diff oil and leave the rest alone. A stiff rear diff does not cause problems off throttle.
#3938
1mm or 1.5mm?
thanks
1mm or 1.5mm?
thanks
Use a thicker shock oil such as Losi 50, 60 or 70.
On bumpy tracks I use 50 or 60 and leave 70 or higher for smoother tracks.
#3939
Originally Posted by gtrmx
Use the 1.5mm drill bit, but only drill one of the holes larger. Leave the other one untouched.
btw what is the overdrive ratio with ED trans standard gearing?
how small i should cut the front tires?
#3940
patto not to worry bud ,thats what we here for
#3941
Try a very thick silicon oil in the rear diff...
After I changed to 50k front and 30k rear the car has been awesome.
I ran 30k front and 10k rear previously ,with the new setup the car juast has more drive out of corners and seems to be more controlled on entry and mid corner ,no need to overdrive the car and be aggressive.
#3942
thank you
#3943
Is the ED trans a good upgrade for my g4? I dont plan on racing i just want the car to be faster.
#3944
if memory serves me correct, he was runing the M insert which is medium ackerman when he stripped it, then changed the insert to L which is stock setting with more Ackerman then M, but i do hope Paul corrects me if im wrong getting older the memory isnt quite the same anymore
#3945
