Serpent 705
#1276
Should I put my reciever inside of a baloon or something? I'm worried about condensation build up if I do that. Any suggestions as to how to waterproof my reciever?
#1277
Re: Re: Hi guys!!
Originally posted by InitialD
Good luck Paul Let us know the outcome.
A little review from my headquarters here in Puerto Rico, to make things more faster here, we only run one qualified of 5 min.. , But the car was awsome in the qualified, until the engine flamed out, in the last 2min. of qualified, so I start at the D main, ,, the behaivior of the car was incredible, with the new FC I was able to improve my previous laps for this track in the past, then I bump for the C main, same thing in this main , everything works good, finishing in first position too, bump to the B main, after 7 min. of the race I took the first position pushing the car to their limits , then i put the cruise control , but in the last two minutes, came the disaster, hehe!!, coming out of the last corner I hit the PVC tube and the pivot ball brake , but no big deal, the car could finish the race running in 3 wheels, taking the first position for me!!
Well guys that's all I can say, the FC works awsome in the car, but with the lightweight pivot balls you have to stay out of the barriers like Punisher said ,, well take care people and happy racing,,
Ciao!!
#1278
Ciao!!
#1279
Punisher or Pit Racer!!
I saw the pics of your rides in the other tread that accord start it, and I just courious about the rear anti roll bar,, how the car handles with it, in My TSN I read that these bar is 3mm in the softer position, did you guys did any modification to get the 1.5mm or just leave it this way??
Just courious
ciao!!
Just courious
ciao!!
#1280
Re: Punisher or Pit Racer!!
Just courious
ciao!!
Just courious
ciao!!
Anyway, the adjustable rear sway bar blades are thick and stiff as what is mentioned on mytsn. The solution is to get 2 of the front male anti roll bar (909216) to replace the ones that come with the adjustable rear sway bar set (909335). Alternatively, you can machine down and thin the ones that come with the set. You need to do them equally on both sides.
#1281
REAR SWAY MOD
THE BARS ARE ACTUALLY OUT OF THE FRONT, APPARENTLY THE STOCK ONES WITH THIS TYPE OF SWAY BAR ARE WAY TO MUCH FOR THIS CAR.
SEE THE ATTACHMENT.
SEEMS TO WORK OK FOR ME,
SCOTT
SEE THE ATTACHMENT.
SCOTT
#1282
My Futaba PCM receiver has been in a balloon always !! since a year ago I own it, never have problems with condensation or anything out of this world, I think is the eaysiest way to cover it , and looks cool too, get a purple balloon too!!
Ciao!!
Ciao!!
Also, how should I charge the stock battery that came with the kit? Do I charge it with my normal charger or my wall charger that came with my Futaba radio or what? I'm not even sure if it is NiMH or not.
#1284
Paul,
The rear adjustable anti roll bar with the stock blades are way to stiff like InitialD and JABRONI mentioned.
I used the front male blades like InitialD suggested and works a lot better then the stock blades came with. The adjustable rear blades are sometimes to stiff for some tracks. They work great on a smooth, big ,high traction track.
Accord,
I have my Futaba reciever shrink wrap....
and on/off switch on the throttle servo!!
Accord,
#1285
I'm not sure what you mean by mounting the switch on the throttle servo. Do you have a pic?
THanks
THanks
#1286
Re: Re: Punisher or Pit Racer!!
Paul, congrats on your successful outing I'm pleased to know that the FC steering blocks worked out well for you.
Sorry Accord no pics for tonight, my friend haven't email me yet with some of them that i took yesterday at the track ,, but the on-off switch I put it between the tank and the trotle servo, I made a hole that only the botton shows up and another two holes for the screws, and of course I use a purple switch cover to protect it from fuel spills,
About batteries, my car is using 750mah, A PCM receiver, 9402 Futaba for Steering and 3003 futaba for the throtle, I put my cells charging over night in a wall charger made by mpi 150mah for the batteries,, and never , never have problems with my car with dead batteries, best probe was yesterday, 5 min. of qualified , plus some test runs, and 45 minutes in total in all the mains I've run yesterday,,
Later I'll post the pics ,, when I get it, for reference OK!!
ciao!!
#1287
Originally posted by PUNISHER
Paul,
Accord,
Paul,
Accord,
Your car looks good with that rear anti roll bar!! I took note of the parts numbers too!! Tnx
#1288
THanks
THanks
#1289
Re: REAR SWAY MOD
SEE THE ATTACHMENT.
SCOTT
SEE THE ATTACHMENT.
SCOTT
#1290
You can put ballon to wrap the receiver but like Punisher, I use shrink wrap, 2 pieces diagonal to each other, that way i had it almost waterproof. Then i use a double sided form tape (about 1mm) to stick the warp receiver to the mount. Shrink wrap again the wrap receiver to the Mount, only then i screw the mount to the upper plate. It is also tough and it works for me. See pictures.
You can get this shrink wrap from hobby store. Its a kind that wrap the Battery stick.
