The moment a clutch begins to engage... >
Like Tree27Likes
Old 11-17-2018 | 01:53 AM
  #166
ralphierace13's Avatar
Originally Posted by fyrstormer
Why would you want a shoe to slip? I dunno, ask people who run Teflon shoes. It might not make much sense for on-road, but a little slip is very helpful for off-road so you don't break traction unintentionally or overheat your clutch and weld the shoe material to the clutch bell.
yes we are talking Onroad
ralphierace13 is offline
Old 11-17-2018 | 03:14 AM
  #167
Roelof's Avatar
I can imangine some oil on the shoe can help to break in the shoe w/o much wear. You want to burn the surface in a controlable way to give a more strong surface.
Regarding slip, yes, it will give a better grip on the car but more important it will keep the engine in higher revs so with a better torque for a faster acceleration after the corner..
blis likes this.
Roelof is offline
Old 11-22-2018 | 12:44 AM
  #168
fyrstormer's Avatar
True, I keep forgetting on-road racers tune their clutches to engage at insanely high RPMs, and in that circumstance you really want some slip because you can overheat the clutch and gall the shoes to the clutch bell in a fraction of a second.
blis likes this.
fyrstormer is offline
Old 11-23-2018 | 09:46 PM
  #169
blis's Avatar
Originally Posted by ralphierace13
Yes I had the same problem you can do 2 things use more washers or use a different collet so the flywheel is further away from the motor, u know I forgot about those washers I’m glad u talking about it I’m going to pick up a few sets ..
That wont work with the collet as the spacing remains the same on the clutch nut.
blis is offline
