Serpent 960....
#3106
Well, i had a clutch problem again recently and i have this issue once back before when i got this car and until now it happens to me again.Ok here is the problem, i got the new yellow clutch shoe installed and it chewed up in powder for less then 1min.....try a new one and it happen again. My engine didnt even up to the temp yet and the endbell was like 305 degreei know it must be something going wrong somewhere. Installed the clutch system as per the instruction sheet, everything is new stock except i got the mugen super hard spring on it and i dont think that will do the damage....... ( captain ) still remember the last time you set up my clutch, after that it was running perfectly smooth and it still the same setup until now but this chewing up clutch shoe thing is happening to me again. Ops...do you know that i am back to my country already? How's the event going on at the capitol classic race? Did the brooklyn boys bring back some goodies? Really miss those days with you guys but hey, do you believe that back in my country here the majority of 1/10 & 1/8 is serpent, there will be 9 out of 10 cars are 960Ops...little out of topic. Any advice of the above mentioned problem will be greatly appreciated.
Happy racing,
Chris
Happy racing,
Chris
#3107
I've seen this 3 times, and all three times the culprit was a warped lightweight clutchbell. Take off your clutchbell and put it onto a very flat surface (such as a piece of glass), and if it rocks back and forth at all, I think it's the reason for your clutch problems.
I won't run the lightweight clutchbell anymore, and I check my 'normal' clutchbell after every run for warp.
Hope you find your problem.
#3108
Hi guys...
Im new in this threat as ive only just went into 1/8 GP recently. Driving serpent 960 07. Simple question, i am using a front dogbone axle. I noticed the front dogbone being a lil too short when turning my steering full, ie. possible of dogbone flying off! I thought of reducing the front width so that my dogbone goes deeper into the outdrives n therefore reducing the possiblity of the dogbone flying off as i turn my steering deep. However, by doing so, the front tires will seem to have contact with my knuckles....any advise besides changing to CVD? thanks
#3109
Guess i have to spend more time figure it out, thanks.
#3111
Hi guys...
#3112
Hi guys...
#3113
What is the correct size of the set screws to put on? Where is the right position of the flyweights to be screw in? Heard some that have success with that modification but have to be aware for that. I will give it a try.
#3116
I think i have the stock flyweights with one hole only for the flywheel pin but will check it tomorrow and maybe just put the set screw in equally. By the way, did you change anything after you have the clutch failure or just add the set screw only?
#3118
Oh....ok. But have you notice that the clutch failure has cause the clutch bell over heat? Mine is like 305 degree and can see little bit of light smoke
#3119
#3120
Happy racing,
Chris
Happy racing,
Chris
