Mugen MTX-3
Originally posted by Arushmen
it is possible to combine the back parts of rool to center?
example: A with B, or B with C.
what will be the result?
I looked at that also, but you will throw the angle off.. The hinge pin will be on an angle, but the blocks are not, so I think it would bind...
On the XRay, they let those pieces rotate so you can do that..
As for my car setup, yes, its pretty much box stock, using either Mugen or HPI tires, 37 shore all the way around, 30mm in rear..
My shocks are in the center holes on both the front and rear, with the car 4.5mm in front, and 5.5mm in rear, with the "A" servo saver.. I'm running 2 deg camber in front and rear, with 0 toe in front, and 2 in rear. I'm still using the stock light blue springs all the way around.. At the moment I'm using a diff in front, but this weekends race is important, so I borrowed a spool.
The track this weekend will most likely be a tight track, but long, and medium to no grip.
My engine is a Mugen X12, and the steering servo is a Futaba 9451 digital..
Thanks for the info all..
I don't know if I had of went quicker had it been right. Maybe
Profoxcg is right. The driving style/technique of the diff and solid-axle is way different. You wouldn't want to figure out how to drive it on the racing day. But, if you already know how to drive it, driving a solic-axle surely give you an extra edge to the winning side.
best of luck,
best of luck,
Originally posted by Profoxcg
If it is an important race you dont want experiement. Just leave the car as it is if its working.
rool centers
If you run an (A) block at the back and a (B) in the front it will give you what is called anti-squat. This will cause the car to rotate very hard late in the corner, and give you more traction under acceleration
Re: roll centers
it is possible to combine the back parts of roll to center?
If your car Oversteers you will need to reduce the anti-squat.
If your car Understeers you wil need to increase your anti-squat.
Now these anti-squat settings are of third order in importance to dial in a car, so you use them if nothing else works
The order of adjustment, in terms of importance, tuning a car is more or less like this:
First order:
Tweak
Tyres
Springs
Camber
Ride Height
Second Order:
Droop
Anti-roll bar
Toe
Third order:
Diffs
Shock mount
Shock oils
Caster
Anti-squat
Roll center
AFM
Re: Re: roll centers
correct me, but I thought the tires and the ride-height would be ranked among first.
Originally posted by afm
Yes, and to round off the idea....
First order:
Tweak
Tyres
Springs
Camber
Ride Height
Second Order:
Droop
Anti-roll bar
Toe
Third order:
Diffs
Shock mount
Shock oils
Caster
Anti-squat
Roll center
AFM
First order:
Tweak
Tyres
Springs
Camber
Ride Height
Second Order:
Droop
Anti-roll bar
Toe
Third order:
Diffs
Shock mount
Shock oils
Caster
Anti-squat
Roll center
AFM
Re: Re: Re: roll centers
Eddie what will be your first to last in every order rank???
AFM
Re: Re: Re: Re: roll centers
Well, actually in every order rank i haven't set them in a first to last sequence, but tires and ride-height are in the first order rank.
AFM
AFM
Lets say you've set the car with the basic manual set-up, and you wan't to fine tune the car, then i would use the order just as I posted it.
Example: Your car Oversteers entering a corner, I would make these changes in order, one at a time:
1.-check tweak
2.-harder front tires
3.-harder front springs
4.-reduce negative camber
5.-raise front ride height
6.-reduce rear droop
7.-stiffen front roll bar
8.-decrease toe out
9.-lay down shocks
10.-increase shock damping
11.-increase caster
12.-reduce anti-squat
13.-raise front roll center (if car allows it)
AFM
I like your order but I think diffs are very important A diff change can and will make the most dramatic change
AFM you should put out a tuning guide I know I would print it out
With the basic manual set up for diffs you're almost on the ball park, and then you concentrate on the issues of my list, and then depending on the track grip / tire combination, you can concentrate on diffs, because if you start with diffs, you can go way out on some important handling issues.
AFM
Need to find some time to do so, and then think on translating it on to English.
I did it over the past four years of compiling information from the net, and from trial and error at the track.....lot of work man.
AFM
Can i drill holes in the first and second gear housing's to make them lighter. Or is the lightened ones that you buy made out of different material.
Will it stuff them or be o.k
One for the pro's.
One for the pro's.
