Mugen MTX-3
#1276
goodies
#1277
mid bearing block
#1278
snake pipe/wire mount
#1279
Goodies
Originally posted by Manticore
goodies
goodies
BTW, how do you find the centax ? More like Kawahara ones or Kyosho ones? fly weight is 3 piece or 4 piece? did you use any special tool to install or adjust the centax?
great pic...
#1280
Re: Goodies
Originally posted by RClover
Manti...what engine is that with a B on the carb? RB?
great pic...
great pic...
the centax is more like a Mugen Centax It is a Mugen !
it has 4 pcs flyweight. I have the spring tension adjusting tool but I merely use it !
#1281
which one manti ?
looks like i am goin to get a second car already.... cant resist the temptation of joining the club....
i am comparing MTX-3 with the 705....
cant decide which one to go for...
is 705 worth it Manti...???
#1282
Re: which one manti ?
#1283
Re: Re: Goodies
the engine is Novarossi S5 but I put on a RB carb on it
spring tension tool? what is this 2 speed clutch tool?
#1284
Re: Re: Re: Goodies
Spring tension tool is to adjust the clutch spring tension.
#1285
Re: Re: which one manti ?
You asked the wrong person. I am allergic to snake so I am going to tell you a bias comment. You should know what I am going to say dude !
#1286
Re: Re: Re: Re: Goodies
that one is particular for kyosho 3D clutch. It is for remove/install pinion on the clutch bell. I am not sure if it fits mugen clutch bell.
#1287
Re: Re: Re: which one manti ?
never mind then... btw, how you rate RR against MTX-3 after testing it out....?
#1288
Re: Re: Re: Re: Re: Goodies
does MTX-3 kit provide this tool? if not, how do you adjust the clutch spring without using your tool? does it difficult to adjust?
It is best to use the mugen 2speed tool as this will save you from buying clutch bells.
alternative for the clutch spring tension tool is your "fingers"
#1289
Re: Re: Re: Re: which one manti ?
2 thumbs up !!
2 thumbs up !!
#1290
Re: Re: Re: Re: Re: which one manti ?
Originally posted by nova racer
out the box the mtx 3 is better than the v1rr?
