Mugen MTX-3
#9901
Originally posted by B
Hehehe, We all know Im not the punk on this thread
#9902
Originally posted by Manticore
you're right ! but EVO is the Punk #1 here !
Seeing as Data is getting a 710 later,maybe you should join him to break the domination?
#9903
Originally posted by EVOLUTION
Speaking behind my back again punk !
domination = one iDiot show ?
#9904
Originally posted by highwayman
Hi... just got a new MTX3 kit... and i have been reading some of the newest pages of this thread, and i'd just like to ask a couple of things:
1. what are the differences in the spring rates (1.7, 1.8 etc)
2. ever expereinced the front diff touching or rubbing against the steering linkage?
3. are CVD's necessary? or will the dog bones do? how do i properly space the dogbones so that they won't fall out?
4. any tips on measuring track width, so that i adjust the left and right pivot balls equally?
5. any necessary hop-ups?
thanks in advance... BTW, i have been running an NTC3 for about a year now, and one of the things that attracted me to the MTX was the diffs...
- jason
- jason
Good choice with this one. I have only one performance hop up
on mine that i think is a must have (16T/19T) side belt gearing. It really improves the handling as well as the rear tire wear issue. You have to run a 4mm split as i was told on the front/Rear tires but they wear evenly and once you get used to it 1 or 2 tanks the kit really sticks at higher speeds through the turns. I've snapped one front dogbone after running over a slow and have been told the front CVD's are a good investment but still running bones with fuel line slivers on each end. I broke my engine in on a nice paved lot and ate up the stock front and rear belts but replaced them with mugen replacements and they have little of no wear showing after 1/2 gallon. The only other thing maybe the Handle as I had to dremmel it a bit to free up throttle clearance. I picked up a nice used NTC3 kit cheap since I bought my MTX and have a hard time controlling it as well as breaking the cheap plastic parts in it and bending 2 cvd's.... If you are good with the NTC you should really appreciate this kit.My Kit is Stock with the belt conv I'm running a Mod STS D3 One piece THS pipe ,MX3 Radio ,Hitec 625str/605t/b Servos and Fast tires 42F/40R Stock on the setup sheet. Good bunch of people here when they aren't whacking Penguins....
#9905
#9906
Originally posted by Fisher890
I have only one performance hop up on mine that i think is a must have (16T/19T) side belt gearing. It really improves the handling as well as the rear tire wear issue. You have to run a 4mm split as i was told on the front/Rear tires
left my kit and manual in the shop, and i can't remember, but isn't this the (16T/19T) the stock pulleys? if so, should i change to the aluminum ones?
With these pulleys (16/19) will the car have an overdrive or underdrive?
i just shaved some material off the steering linkage links and de-burred the diff casing so that there is now some clearance.
#9907
Thanks ... the penguin game must be very addicting...
what you need to do the conversion is get an extra 16T pulley, put the rear 19T to the front and affix the extra 16T to the rear. and at last you need a shorter side belt. kawahara carries the shorter long belt for this conversion and there is someone on this forum selling the shorter long belt.
i tried the alloy pulley and i dont like them as they wear too fast. stick with the plastic pulleys.
with the 16/19 conversion, you may use smaller tire in the front which is the purpose of the 16/19 pulley conversion.
why you need to shaved your steering linkage and deburred the diff case?
#9908
the 16/19T pulley conversion is referring to the side pulley with the long belt. stock pulley there is front:24T and rear 19T
Thanks... so the 16/19 conversion is an overdrive? that's why we can use smaller tires in front?
with the stock pulleys, is this neutral, meaning the front and rear tires spin at the same time?
i'll stick with the plastic pulleys...
The ball cup that is in front of the diff case touches and i can't seem to find anything wrong with my assembly...
#9909
i havent any chance to use a front diff. i thought you were talking about the rear diff !
#9910
how about a front fix shaft? anyone tried?
#9911
#9912
May i know how to make the front fix shaft?
thanks.. would like to run on rubber tires as well.
#9913
i made a block to replace the gears in the front diff.
justrc sell some as do kawahara if you do not want to make one!
#9914
thansk for the infor.
#9915
this is the kawahara parts to turn your diff into solid axle.
