Mugen MTX-3
#9738
Originally posted by over gear
Guys, how do you check if the clutch is working fine? how do you check for slippage?
you should let ah10 help you on this.
#9739
Originally posted by mtx3racer
nothing really, slides a little, but i want to try some others. Have any that you are willing to share? I would appreciate it very much!
Front:
- Track width: 196mm.
- Ride height: 4.5mm.
- Sway bar: 20º.
- Toe-out: 1º (0.5 each wheel).
- Caster: ???. 2 shims in the front of the A-arm (the thick one and one thin).
- Camber: tyres should wear flat or slightly coning inwards.
- Ackermann: B plate.
- Droop: Very 'tight'. Probably 1 or 1.5 measured on a hudy tool.
Rear:
- Ride height: 5mm
- Sway bar: Stock one (2.3mm) slightly tightened.
- Toe-in: 2º each wheel.
- Camber: Tyres should wear flat or slightly coning inwards.
Tyres: 40 shore everywhere. Rears cut at 63mm, fronts at 60mm (16/19 conversion).
#9740
Hola Corse-R:
What difference can you notice in the handling of the car by using 196 mm trackwidth as opposed to close to 200 mm.
Jose
Jose
#9741
Originally posted by stefan
yes you are correct, you can tell that the plastic ones broke when a corner marshall is picking you car from the wall.
The aluminum ones "might" bend (mine haven't after a lot of miles) but they WILL stay on the car and you'll finish!!!
Remember, to finish first, you first got to finish.
#9742
Originally posted by EVOLUTION
I had one of my hubs crack from a collision but it was a decent hit to be fair.I'm hoping kawahara will bring out some delrins later on but in the meantime at least the GPM ones look trick.
#9743
Grinder,
you neglected to mention how many races you (and Nick for that matter) didn't finish because of knuckles and CVD's and how often that happened to me
#9744
Originally posted by Manticore
look who is sponsored by GPM? you punk !
If you don't like their stuff for whatever reason, DON'T BUY IT and get over it.
I have found a very good product from GPM (which you most likely haven't even tried) and no matter how often you bash it, I'll still like it.
It seems to me that you have "brand name issues"
#9745
#9746
The problem is that you are giving people bad advise.
Remember when we talked about 3 racing aluminum pulleys here and you told everybody that they are crap and the Kawahara pulleys are the way to go.
Turned out that it was exactly the other way around, didn't it.
Same with those knuckles. You make it sound like people are making a million dollar mistake by trying those.
They are 20 bucks at the most for Pete's sake, so leave it alone already and let people decide for themselves, would you?
I know for a fact that the Kawahara Delrin stuff is by far not what people think it is, but I'm not on a quest to talk everybody out of it.......
#9747
there are two issues to the alloy knuckle.
1/. it is alloy. what I dont like is what I dont like. you cannot stop me. and not only me gave advice the alloy part here is just transferring stress to the next parts on the car.
2/. it is GPM. yes, the brand name and the quality. you think you are giving good advice to people that they make good quality stuff? only newbie will say this stefan.
#9748
I'm not telling people that GPM is making good stuf in general, I'm telling people that the GPM aluminum knuckles for the MTX3 are a great product.
You are the one generalizing everything that comes from them.
You did exactly the same with ALL the stuff from 3racing.
Also, if you also think that the 3 racing pulleys are crap, than I will have to tell you that I cannot take you very serious anymore.
Me and other people ran these pulleys for the whole season and most of them look almost new.
I'm sorry but I will not discuss this any further, no point to it.
#9749
I am a consumer and have the right to tell the bad and the good. and this is why people come to the forum and pick up the information about particular product.
like i always said, only company staff will protect their product. If you are staff of GPM or 3racing, take my advice and go improve your products.
#9750
Manti, your GPM bashing is getting old now.
OK...you could say for alloy parts they are cheap.....however, what ticked me off the most was the arrogant guys behind the counter....
If you were in Hong Kong, you would know that the GPM name is somewhat linked to poor quality by pretty much everyone who has been in RC for any length of time......so how do they survive? Well, pretty much purely from the overseas market and picking up the newbies around Hong Kong. The prices I've seen in US mags are about double the price in HK, but hey...they can still sell it. I give them credit for their business sense....but definately not for quality.
I would put GPM right down at rock bottom.
3 Racing however, is not that bad...they feature very well in terms of value for money......
