Mugen MTX-3
#946
New product for MTX-3
Team Osaka
MTX-3 HKD$2550
MTX-3 HKD$2550
#947
A long rod motor is more of torque motor because it had more dwell time.The piston stays at TDC longer.Were as a short rod motor will be more of a rpm oriented motor.It will not necessary make more RPMs,but it should make more power at higher rpms then a long rod motor.Its kinda hard to explain.Hopefully Dennis will explain it better.
#948
Here is a link that describes the long rod-short rod theories.The article is on car engines but it will give you the idea.
http://www.stahlheaders.com/Lit_Rod%20Length.htm
#949
Your right.
On our twistier track the MT has the advantage whereas the RB has the advantage on our faster flowing tracks. That tells me (now after I have woken up) that the MT produces more torque.
Thanks Craig.
Thanks Craig.
#950
What RB do you have? I have looked at some of them but as you know they make alot of different ones.
#951
I have an RB X.12 3-port SG Shaft. (Gold Head). 2yrs old, modified and still going.
#952
We will have our new 5 port motor avalible next month.
#953
#954
Re: New product for MTX-3
Originally posted by LeoChan
Team Osaka
MTX-3 HKD$2550
Team Osaka
MTX-3 HKD$2550
#955
Want compound of tires does the MTX3 like? On the NTC3 where we race it liked 40 on all four corners.
#956
Re: Re: New product for MTX-3
Originally posted by ROBBIE C
These parts are not from Mugen and they are not from Osaka.
so, where do you think they are from? I have a few of them in my possession ! they are of very fine quality.
#957
i would think the tires you were using before would probably work provided the front and rear compounds were different like grp foam
i know i plan to run 40 front and rear in spring maybe 42 in summer
the kit comes with 37 and the car was dailed for me running on a loose parking lot track im sure 40 will work on my normal track
#958
Re: Re: Re: New product for MTX-3
#959
Re: Re: Re: Re: New product for MTX-3
Originally posted by black-knight
they are gandini's (GRP)
#960
i was wondering the same thing
