Mugen MTX-3
Old 11-25-2002 | 10:37 AM
  #766
fraz's Avatar
Don't cut that piece off entirely or you will have no brakes! You should only have to shave a little bit of it to get the brakes freed up as I did the same thing on my MTX-2.
fraz is offline
Old 11-25-2002 | 11:01 AM
  #767
Francis M.'s Avatar
I haven't bought the mtx3 reserving judgement until
I can see one run at my local track and after seeing
the run robbie put together yesterday It made me
want to buy one that day. from what I saw the car
had the same straight away speed as the tc3 with
better corner speed and it almost looked like an electric
cars in the in field
Francis M. is offline
Old 11-25-2002 | 12:16 PM
  #768
Default Brakes binding
Originally posted by ROBBIE C
Earlier I posted the proper way of fixing the brake problem, sounds like no one paid attention, so here it is again.
grind down the brake guide on the rear cross member, this should solve your problem.
I listened!
I came to the same conclusion. I did a bit of everything!
Sanded the brake pads.
Sanded the brake guide on the rear brace.
Bent the pins VERY slightly (I'm not sure if this is necessary)
I just kept tweeking untill I was happy. It involved stripping the rear end about ten times checking every componant but as I said in an earlier post sure this is half the fun of building!
All the best
click, dublin is offline
Old 11-25-2002 | 12:41 PM
  #769
patelladragger: if you put only one disc, be sure to put more material on the flat part of the brake shaft and the brake stops up and bottom on the left, because i don't think a single disc is thick enough to be in the range.
one thing you guys may want to try, or maybe you already did.
place two 3-4mm washers above the fuel tank ears. your tank will sit 3-4mm lower. but be sure that the tank isn't touching the chassis!
ME-student is offline
Old 11-25-2002 | 01:06 PM
  #770
ROBBIE C's Avatar
You got it
ROBBIE C is offline
Old 11-26-2002 | 06:41 AM
  #771
IT'S NOT!
Just enlarge the pin holes a bit to free up the brake plate, this helps a lot.
rranger is offline
Old 11-26-2002 | 07:18 AM
  #772
I just don't know why so many brake problems around here, I did mine as per manual and polish each parts a bit then a perfect brake is done, It has no drag at idle and perfectly stopped my car on the straight.
rranger is offline
Old 11-26-2002 | 07:22 AM
  #773
Manbik's Avatar
Originally posted by rranger
... It has no drag at idle and perfectly stopped my car on the straight.
You are supposed to go fast when on the straight parts.
Manbik is offline
Old 11-26-2002 | 09:13 AM
  #774
i just followed the instructions and my brakes worked great
jason102276 is offline
Old 11-26-2002 | 01:39 PM
  #775
i listened and told dublin!! but was busy bout his pipe.
any one found the front belt slack?
put a small washer under the front screws on the front lay shaft mount!
Cartman is offline
Old 11-26-2002 | 03:42 PM
  #776
ROBBIE C's Avatar
Parts and tires are now in call your LHS.
here are the different tire shores that are avalible.
35 fronts
37 fronts
40 fronts
42 fronts
45 fronts
35 rears
37 rears
40 rears
42 rears
45 rears
I would also sugest that you use the MTX-2 front dog bones on your cars, they work great.
ROBBIE C is offline
Old 11-26-2002 | 04:46 PM
  #777
ROBBIE C's Avatar
You guys should try running the new 2.1 Stratus from Portoform, It is the best body that I've ever run, good steering and verry stable. This is the body that I recomend for this car.
ROBBIE C is offline
Old 11-26-2002 | 10:18 PM
  #778
Alvin's Avatar
Greetings,
I too have an MTX3 as my first nitro tourer, and whilst I am still bitching about the engine (I need a starter box!), indeed comparing how the car handles *on rubber*, the stock setting's handling feels very similar to my trf414m. I have tried V1rs and impulses before, all off 'em had quite boring reaction timing in the corners. Whereas the MTX3 was able to do chicanes and hairpins like my 414m. This is bad. I may actually want to race nitro!!!!
Alvin is offline
Old 11-27-2002 | 12:23 AM
  #779
microRCshop's Avatar
Hi Guys,
Most parts for MTX3 are available now. More parts are coming in 1-2 days. So if you don't see what you want just placed your name on the wait list.
Also, Proline Stratus 2.1 and PF-1 LMP 1/8 scale onroad bodies are in stock
Vince
www.microRCshop.com
microRCshop is offline
Old 11-27-2002 | 10:15 AM
  #780
Right, but sometimes you have to stop. you know that.
rranger is offline
