Mugen MTX-3
Old 11-19-2002, 12:32 AM
  #616
SpeedTech's Avatar
JPHRacer,
yes, the MTX-3 comes with a centax. As for foam tires, the rear uses a +2 offset is what I'm told. So the Jaco 2 offset tires will work, or the new Mugen MTX-3 line of Fast foam tires will work. I think yokomo's new 30mm foam tires are +2 off set as well (i'm not 100% sure though)
Steve Wang
Speed Tech R/C
www.speedtechrc.com
SpeedTech is offline
Old 11-19-2002, 12:41 AM
  #617
CSF0623's Avatar
ME Student: what do you like about the car compared to your NTC3? Does the car have more steering, is it stable at high speeds in and out of turns, and hows bottom and top end speed? Give me the scoop!
CSF0623 is offline
Old 11-19-2002, 01:51 AM
  #618
CSF0623: i only ran a couple of tanks, but here is what i think...
this car handles well out of the box! with stock setup.. it handles as well as NTC3 if not better, it had a little bit of understeer in some area of the track but i still think its steering is comparable with NTC3.. it changes direction quick also.. i believe it is a little bit more stable than NTC3.. but this is just my opinion..
this car is punchy...! well..i am using the stock gearing though.. you have to put that into the consideration...
but the gearing system on this car is better than MTX-2 since you can use a bigger split between first and second gear.. so you can have more top end without losing bottom.. i think you know what i mean..
ME-student is offline
Old 11-19-2002, 03:39 AM
  #619
sparksy's Avatar
Trader Rating: 14 (94%+)
Default tires and rims...
I was at the local hobby shop today, and we were able to fit standard fast tires and rims to the car with no rubbing.... 30mm rear and 26mm fronts.... the car was a roller so the fronts might rub when servo/steering arms are on....
sparksy is offline
Old 11-19-2002, 05:04 AM
  #620
Taylor-Racing's Avatar
Originally posted by patelladragger
woa -a body makes a difference huh? What a shock! Maybe I'm not quite the fool after all... You need to post this on the V1R thread to enlighten.
Got my mtx3 but no time to build it yet. Made a receiver pack before it got here sautered up with 5 AAA but I made them flat
Awww . . . c'mon patella, no one said you were a fool.
Then again, the way you assembled those batteries . . .
Just joking , now . . . OK.
Taylor-Racing is offline
Old 11-19-2002, 05:26 AM
  #621
AMGRacer's Avatar
I thought we had decided that bodies make no different to bad drivers like us
AMGRacer is offline
Old 11-19-2002, 05:49 AM
  #622
Well, given that at the end of that discussion, we agreed we were all saying the same thing, this now raises the possibility that we might ALL be fools.
Old 11-19-2002, 08:41 AM
  #623
patelladragger's Avatar
patelladragger is offline
Old 11-19-2002, 08:45 AM
  #624
Originally posted by ROBBIE C
Motor kits come with tuned pipes
my kit didn't have a pipe either. it has the motor and header but no pipe. The instructions didn't list a part # for the pipe so I just assumed it wasn't supposed to have one.
Old 11-19-2002, 08:53 AM
  #625
believe me when I got the car and saw the instructions I was ready to put on my "I'm an Offical Fool" cap.
I assumed since mrx3 uses flat pack, and this is baby brother, and I read on here that i need AAA that it just needed AAA flat. WRONG! It was a lovely job though, pro-match couldn't have done it any better.
the problem is nobody has the pack part # Robbie keeps posting. So i'll just have to get the Weller out again.
Old 11-19-2002, 08:59 AM
  #626
snoopy's Avatar
None of the kits come with pipes. Only standard manifolds.
snoopy is offline
Old 11-19-2002, 09:05 AM
  #627
CSF0623's Avatar
Me Student: thanx for the info. It really is good to hear from other local racers about the new car! Will you be at CP or Revelation this weekend?
CSF0623 is offline
Old 11-19-2002, 09:24 AM
  #628
robbie do the trinity reflex pinions work on the new centax
i was wondering why dogbones are falling out are you running 200mm with 0 offset wheels? if so could the old mtx-2 dogbones remedy this i know i personally have quite a few leftover from upgrading to universals
jason102276 is offline
Old 11-19-2002, 09:26 AM
  #629
where did you get the AAA cells and what mah rating are they also what did you use to connect cells together wire? or is something better available?
Old 11-19-2002, 10:02 AM
  #630
ROBBIE C's Avatar
Originally posted by CSF0623
Brotha Man: What up! Thinking about doin' the switch!
Felzie.
Whatz up Felzie you know your body already fits the car lololololololo
ROBBIE C is offline
