Mugen MTX-3
#6646
Originally posted by puma1824
Fast Tyres, Power Tires, or Elligi? Which do you guys like better? Have you had any long term problems using the 0 offset tires?
-Puma
-Puma
I've been using the Zac tires 0 offset, and have no problem. I use what I like and what my wallet likes best!
#6647
Power Tires
The rims break easily....same foam, but the plastic is more like glass! We've all been using Fast Tires and Ellegi.
I'm also experimenting with rubber. Currently trying out Sorex 36r's, but I think I need to lose the anti-roll bars and soften the springs...
Anyone have any success stories with rubber on parking lot surfaces? Tell us the setup, please.
#6648
Tweak Station
Hi:
A fellow racer in Puerto Rico was using a Speedmind tweak station the other day. I liked it a lot and looked on the internet hobby shops but could not find it.
Anybody knows where to find it and any comment on its usefulness as compared to the MIP. I know Integy makes one but it is a lot more expensive.
Thanks for your comments on the lost brake pins on the MTX-3. I ended up using broken shock shafts from my Impact. Put some CA glue on them. Hope they stay.
Jose
Jose
#6649
Re: Tweak Station
Originally posted by joseviejo
Hi:
Jose
Hi:
Jose
#6650
Re: Tweak Station
Hi:
Jose
Hi:
Jose
besides, look for area that is enough to use set screws to affix the pin instead of using glue.
#6651
Re: Power Tires
#6652
Re: Tweak Station
Hi:
Hi:
#6654
Re: Re: Re: Tweak Station
Originally posted by Manticore
i think the speedmind tweak station has similar design to the MIP one, isnt it?
#6655
Fuel tubing
Erm may i ask you guys what are the optimium
length of fuel tubing to run from tank to engine
and from tank to pipe..
what are the effects in running a longer pressure tube?
thanks
thanks
#6656
#6657
Re: Re: Re: Re: Tweak Station
Originally posted by dtm
Nah...Speedmind is not balance because the spirit level is located on one end.....the MIP is "perfectly" balanced.....it moves even when I turn the air con in the room!!!
#6658
VINYARD- The longer the pressure line is the more constant pressure of fuel your giving to the engine. shorter line is worse. Think about it, if you have a longer fuel line you can maybe get 1 or 2 laps while others are pitting
#6660
Originally posted by mistercrash
Pardon my ignorance but doesn't a nitro car on foams become tweaked as soon as the tires start to wear unevenly during a race?
