Mugen MTX-3
#4921
Thank's Ed the fish, I'll buy one and replace my worn front belt.
#4922
where to find the wed side od the mtx3,,, can any one tell mi thank you
#4923
Re: Re: Re: 363mm custom Belts order.
Originally posted by Corse-R
Is for a 16/19 conversion and run different size foams (3mm split F/R) to cope with the wear of the rear tyres faster than fronts. Very interesting on Finals where you need to survive 30 or more minutes with the same tyre set.
Does this actually work well in terms of equalising tyre wear?
What has been your experience?
#4924
Re: Re: Re: Re: 363mm custom Belts order.
Originally posted by Taylor-Racing
Corse-R,
Corse-R,
that's one of the advantages
#4925
just picked up a pair of eagle racing rear CVD. Is this the same as 3 racing?
#4926
the pins are smaller than the mugen i think..
#4927
Re: Re: Re: Re: Re: 363mm custom Belts order.
#4928
#4929
RC Lover,
Integy (Eagle) and RD Logics parts are re-packaged 3 racing parts.
#4930
Hey race fans!!!!
Can someone tell me if having a fifth body post helps at all or is it just something that the cool dudes do?
#4931
manti
is the rear sway for the mrx3 will fit the mtx3?
thanks
nelly
thanks
nelly
#4932
Originally posted by TBR
Hey race fans!!!!
Hey race fans!!!!
#4933
Originally posted by dg8one
manti
thanks
nelly
manti
thanks
nelly
#4934
Originally posted by stefan
Corse,
are you using the regular Mugen pulleys for this conversion,
a 16 tooth on the rear (transmission) and the 19 tooth on the front shaft?
Corse,
#4935
Corse-R,
Corse-R,
Probably will swap to the new pulley system on the forthcoming National race (very very abrassive surface, almost sandpaper).
