Mugen MTX-3
#4111
Sorry who is Smeltz??
Does he tune engines does he?
#4112
Originally posted by penggoy
who made the M1RR?
Manti can I be ur friend so u can give me ur MTX3 when MTX4 comes out
Ok guys this came from Smeltz himself
Sirio 3 port is ok but modified is not. One thing I have come to find on the Sirio is that the bushing on the conrod that connects to the crank pin is badly manufactuered. Brand new out of the box it has considerable play, not all but most and until sirio fixes this problem I will not modify them. On one of my test motors it shattered and damaged the motor. It is not so bad for stock but after modifications that conrod wont handle the 40,000 plus rpms for any period of time. --- SMELTZ
who made the M1RR?
I checked my sirio which has gone thru 1/2 gallon of fuel the conrod still stand right.
#4113
Originally posted by RClover
Good morning manti,
had your BBQ snakey this morning for breakfast...?
one guy asking in the other forum as to which engine he should put in his new 705...
Good morning manti,
Regarding the engine.... who cares?
Antoniop: You know that the next month I'll await some e-mail or similar saying that come to ARCA (who cares if we 100 or 101... the more will be, the better). On August will go to Vila Real.
BTW: How about this avatar? A friend sent me but.... what do you think about it? Should I have the guts (or b....) to
#4114
forget to put the avatar
Uhm!
Forgot to post the avatar... Early Alzheimer?
attachment removed. Kids visit this forum too.. -TSR6
#4115
Re: forget to put the avatar
Originally posted by Corse-R
Uhm!
Uhm!
#4116
Hi all,
Yesterday i was experimenting with cutting my tires with camber. 1 deg front and 1.5 deg rear gave a tremendous grip, but the extra grip of course increased the tire wear. My 42 sh Speedminds would never last a 45 minute final
Any one else with any experience with this ??
//P
//P
#4117
Originally posted by PontusO
Hi all,
Hi all,
Running a 45minute final is a quite demanding moment for the car and their setup. For those long mains I cut the rear tyres 1mm larger than the fronts (at starting isn't too much quick, but about 8 or 10 minutes they start being 1:1 and about minute 22 or 25 they start being quite lower than the fronts and the handling varies, but other guys started being slower before you).
#4118
?¤•i”Ô?† ?¤•i–¼ ‰¿Ši
T0251 1st. ƒMƒ„ 58T (0.8M) \350
T0252 1st. ƒMƒ„ 59T (0.8M) \350
T0253 1st. ƒMƒ„ 60T (0.8M) \350
T0254 2nd. ƒMƒ„ 52T (0.8M) \300
T0255 2nd. ƒMƒ„ 53T (0.8M) \300
T0256 2nd. ƒMƒ„ 54T (0.8M) \300
T0714 1st. ƒMƒ„ 20T (0.8M) \900
T0715 1st. ƒMƒ„ 21T (0.8M) \900
T0716 1st. ƒMƒ„ 22T (0.8M) \900
T0718 2nd. ƒMƒ„ 25T (0.8M) \1,000
T0719 2nd. ƒMƒ„ 26T (0.8M) \1,000
T0720 2nd. ƒMƒ„ 27T (0.8M) \1,000
T0721 2nd. ƒMƒ„ 28T (0.8M) \1,000
T0722 2nd. ƒMƒ„ 29T (0.8M) \1,000
#4119
and this gear ratio reference chart
#4120
-> Corse-R
Have you experimented anythig with overdrive. I have found that my car works best when i cut the fronts 1.5 - 2 mm larger than the rear to get a little bit front overdrive. Having said that i dont really like to cut the rears smaller than the front since they wear faster. Do you know if there are any pulleys available that can give me a little overdrive in the front ??
/P
/P
#4121
How do u guys do the rear floating body mount? What are the pros and cons of it? I saw someone posted his car with floating body mount using V1RR parts. Do u guys know their part #? thnx again
#4122
Uhm!
Uhm!
#4123
Re: Re: forget to put the avatar
Originally posted by Pepe
Did they banned your avatar??? I couldn't open it!!!
#4124
They were not inapropriate, they were huge and lovely, SPOILER!
#4125
..and what's that with kids being on this forum.
Boobs is one of the first things kids see after they are born.....
