Mugen MTX-3
#3931
Raced the Mugen for the first time today, with basicly the box setup. I was very happy with the way that it drove, and it was good right out of the box. The only real issue that I had with the car all day was the loosening of steering screws, which I never put lock-tight on when I built the car.
It was a little looser than what I would have liked, but it was driveable. The 2-spd shifted a little later than I wanted, so I did adjust that a little bit, still not enough.
I burnt through the 37's though.. wow.. My rear tires have about half a day left on them, and the fronts probably would make it through a whole day.
-Troy
-Troy
#3932
I'm running 40's all the way around (sometimes run a 42 on front, but usually just 40) with the box set up except a little more ground clearance, and purple front springs.
#3934
Re: Kevin,
Originally posted by stefan
Mugen's fuel is from Byron..
#3935
optional chassis 4mm
hi, who has been using the optional chassis 7075 ? recently, there were many aftermarket 7075 chassis and it's hard for me to choose from ? does the 3-racing 4mm have the offset area in the engine mount ? any other choice ? thanks
#3936
Re: optional chassis 4mm
get either kawahara or mugen 4mm, they both have recess areas to keep low CG.
#3937
Re: Finally....
Originally posted by BOLISARIO
Got this thing built and ready to run, I hope. It was harder,for me, to build this thing compared to the GT4 and NTC3. Lots of tight spaces and a whole bunch of screws.
By the way, did your kit come with a flywheel collet? I didn't find one in the kit or the instructions. I just used the collet that came with the MR12(bought it separately). It seems to fit right and the pinion/spur combo matches up well.
#3938
Re: Re: optional chassis 4mm
Originally posted by Manticore
3racing 4mm is the worst i have seen.
I have rune the 3racing chassis for a few month now, and I love it.
#3939
Re: Re: Re: optional chassis 4mm
Manti, why would you say that?
pricewise, their chassis for MTX3 is way over price and material in use is in doubt. the mugen or the kawahara one are just the same price level but you will get better product quality. i.e. value for money.
#3940
16T & 20T pinion
They last a little bit longer then MTX2 pinion !
#3941
16T & 20T pinion
another one
#3942
help manticore
hi manticore can you tell me what's the kawahara 0.8 mm spur gear combo sot suippose to do i saw it on their website but have no idea what does it do?also is it worth getting?
thanks
thanks
#3943
does the 3 racing have a web site. and from what I can see the three racing chassi does not raise cg but steals 1mm of ride height. Since the extra mm is below the hinge pins I dont se how that raises cg. If I am wrong please explain. jack H
#3945
MTX-3 & Wet weather
Hi Guys,
Had a bad day today at the first round of the MMAI national championship.
It rained VERY heavy throughout the day, the rain was hopping off the ground about 2 feet!
We ran our cars in between the showers.
First I lost a throttle servo, then I had a problem with radio glitches, water in the receiver!
Then my two speed started to act up going down the straight it sounded like it was attempting to go into 2nd then drop out then back in, out, in etc.
I did manage to keep ahead of a 2003 SMP Slide for about 4 laps . . . he was on foams & I was using wet weather rubber!!
Any ideas on the two speed?
All the best
All the best
