Mugen MTX-3
#2821
Originally posted by eddiethefish
I've also found out that their term of "Rear Rigidity" is what we all know as "SOLID AXLE".
#2822
Freakah,
yeah, I'm not a big fan of purple, my MTX2 was all red.
I love the car. I was very competitive with my MTX2 for the last 2 years, but first race this season, I was a lap down in qualifying against a lot of MTX3's.
So, I went out got the car and was on the pace immediately the first time out. I gained a good second per lap on a17 second track
Setup: I cnaged the rear end a bit.
50,000 wt inthe diff
A-Blocks
Shocks all the way down
2 degrees toe in and 2.5camber
I run 42/42 Mugen Foams (the rubbers are just my "parking tires")
Manticore, thanks.
A-Blocks
Manticore, thanks.
#2823
Puma, it's a Kawahara head.
#2824
#2825
Yeap, it's ZAC Project by Kawahara KZ-1710 or 1711 if Purple Anodized is your preferable.
#2826
stupid front diff leak is really getting on my nerves.i did EXACTLY what you guys told me to do:fill up to the cross,makes sure i dont overfill,both sides of diff are clean,and applied air seal on both sides of the gasket(waited 20mins to set and 1hour to cure).the REALLY SUCKS!!!!mugen has to make a better diff,the rear diff isnt leaking beacause the cap is very thick and rigid,not like the front diff cap,its thin and flexy.i really wish someone could make a hope up for the front diff.
#2827
Like I said before, Air Seal is too thin. Use automotive RTV silicone.
#2828
mine and many others have leak free diff so its not mugens doing some thing wrong!!!
#2829
-Puma
#2830
#2831
Originally posted by puma1824
Where can I get the Kawahara head in the USA? Anyone sell online?
-Puma
-Puma
#2832
I had the same problem with leaking fornt diffs. on my MTX-2 and the rear on MTX-3. Try this: Use some sand paper and sand down the diff case (Part T0220E). Sand the part it meets with, Part T0220D. This creates an even smoothe sufrace on the diff case. I used this method on the diffs on my MTX-2 and now on the rear diff on my MTX-3. My diffs never leak.
Let me know how it worked out.
#2833
Also, Kawahara will be making the rear sway bar. I wonder if they'll make a blade type and hope it will perform much better job than the 3Racing.
What is your opinion on the rear sway bar 3Racing makes?
#2834
ive heard it is kinda soft even in its hardest position but i dont have it because of hearing this so i dont know for sure
#2835
I've seen the Serpent 835 one and hoping that Kawahara would match its quality. Oh! Well... just my $0.02.
By the way, what's up with this "just my two cents" anyway? Is it some kinda slang that I didn't know 'bout?
