Mugen MTX-3
#2086
Originally posted by modellor
Yeah. I run a Carbon chassis on my Yok. It really descreases the weight so shifting the CG upwards a couple of mm's is a small price to pay for extra acceleration on smaller tracks.
#2087
Originally posted by Hum
The metal chassis is also a big heat sink for your engine... Carbon is a bad conductor so you'll probably find your engine overheats running on a Carbon chassis
#2088
With TC shells overheating seems to occur but not a big deal of difference really. You will probably change your engine a month or 2 earlier.
But with the Lola shells their is very little difference in temps as the engine is constantly cooled anyway.
#2089
CG Lowering recipe....
For lowering your CG (and maybe your weight) the recipe is easy...
Some ideas...
DON'T Touch the chassis and steel screws that go on the underside of the chassis plate. All the rest is susceptible of weight removing (Titanium screws on the radio plate, titanium pillowballs on the upper side of the upright, keeping the lower of steel).
Keep your steering turnbuckles made of steel, are quite low on the car.
Lightening the transmission raises a little your CG (you're lightening some parts that go pretty low, but are reducing their polar moment of inertia so you get more power to move and change the speed of the wheels) but can be easily fixed putting some lead on the main chassis.
Do not swap the aluminium nuts for titanium ones.... Titanium weights more than aluminium, but swap all the screws on the upper side for titanium ones.
Swapping the stock disk brake for optional ones is a no-no... almost all of them are made of steel and previously you wanted to reduce weight on your transmission.
Next week I'll post some photos about all this with some interesting data.
Some ideas...
#2090
Originally posted by Ah10
Oh my god! that makes perfect sense! I learn something new today again!
#2091
It will be lighter helping with acceleration around our nice tight tracks in the UK but if it lowers the CG because its milled out I am going now to get my dremel out. lol
Making the chassis lighter and reducing its total amout of metal will actually raise the CG in effect. Because you are making the heavier part at the bottom lighter.
c of g i agree with your bit
#2092
I asked Robbie Collins about the weight (on Starting Grid). He said he'd find out next week. Personally, I hope it's heavier than stock. My car is barely race legal in it's stock form. I'm in the process of lightening drive train components, so I fear I'll be seriously underweight. Hopefully the new chassis is heavier to give me back some of the weight with the added benefits of it not being on rotating mass and it being low to help the CG.
#2093
My car weighed 57.3 oz. with a dry tank, bone stock, STS engine, 1-piece RD Pipe, HiTec electronics, Novak XXtra, Stratus 2.1... 60 oz. is the ROAR limitation I believe.
#2094
I beleive the MTX-3 uses the same brake disks as the MRX-3, if so this may be helpful and interesting.
Stock brake Disk (MRX-3) - 14 Grams
Kawahara Brake Disk - 15 grams
Mugen Optional Brake Disk - 13 Grams
#2095
Yep. The Kawahara is so beautiful!
#2096
most of kawahara hop up are eye candies !
#2097
Ahhh... thanks Manticore.
#2098
does anyone know the roar minimum weight in grams?
my car w/body is 1795g no fuel no transponder
i got chassis from justrc its considerably heavier but i had bent the stock one this one is stronger and cheaper
engine mounts from justrc weigh 1/2 aluminum finned mounts
#2099
Chassis should be massive to put those kind of weight on your light MTX3 all the guys I've asked it were slightly under the minimum weight.
#2100
Originally posted by Manticore
kawahara disc rotor made with soft iron metal !! the hole for the adaptor pin deform and wear out fast !
What you think about this disk brake? It's made by an Italian manufacturer for MRX3... Very cheap when compared with the Optional Mugen (Only 25 Euros vs. 62).
