Mugen MTX-3
Originally posted by NitroNubee
That's some great info! WOW Scott! If the X12 is the slowest engine, what else do you have/run?
Stock Mugen x12
JP mod Mugen x12
Murnan mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova NSR 12L3 hotmod
Nova RR 12L3 hotmod
Haven't even tried the FX engine yet.
Too many darn engines.
The RB and the Nova RR are for sale.
Originally posted by evilsike
I'm looking through nitrohouse and they have the fine pitch but all are above 16/20 on the pinion and more(or less) than 47/43
does this also means that the fine pitch pinion will only work on a fine pitch spur gear? I don't mind buying both, I just hope not all of ooptioned gears.
my pinion gears right now is as sharp as a razor blade
thanx again
thanx again
1st: The mesh is smoother and therefore the power transfer is smoother and has less resistance. Less power loss. YOu can also make more subtle gear ratio changes.
To answer the other question, you must use .8 pinions with .8 spurs. I have only run .8 gears, but if it is time to replace pinions, that would be the most economical time to make the switch.
Stock .8 gears are 21/27 and 53/59
your crazy "fish" just crazy...
Earl "da squirrel" tells me your goin' down to Rev for the McCoy race????
good luck dude, (even though you don't need it....)
do you plan on making a stop over to Ultimate some time this weekend (they should be at the new location) if so, "I need a favor....."
(Yeah, I think you know why)
not planning on going to ultimate, but it doesn't mean I can't. Actually, I don't know what the heck you need. If I make any extra stops, it will be to RCX. Not planning it, but I might. You could just call me back, like you said the other night.
Originally posted by Scott Fisher
Currently my engine area contains the following:
Stock Mugen x12
JP mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova RR 12L3 hotmod
Stock Mugen x12
JP mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova RR 12L3 hotmod
what do you think of your jp mod mugen x12? i have a few of them and love them... i am going to get a murnan mod here sometime as well.
Stock Mugen x12
JP mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova RR 12L3 hotmod
Stock Mugen x12
JP mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova RR 12L3 hotmod
Thanks!
Suspended
Rebound stop/droop
Reading the setup sheets from mugenracing.com (such as Tim Long's '03 Ft. Myers), is the rebound stop (both front and rear) measured by lifting the chassis at its center line 'til the wheels lift from the board or is it measured by placing a droop gauge under the up-right blocks?? Tim had it set to 2mm front rebound and 8mm rear. I'm little confused by it... Please help me understand this.
Thanks!!
Thanks!!
it is measured with the droop guage.... and the blocks under the chasis
Suspended
thanks joe, i thought that was the case just got confused reading other opinions on this subject... thanks again
Stock Mugen x12
JP mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova RR 12L3 hotmod
Stock Mugen x12
JP mod Mugen x12
Jp FX t-03 mod
Rody RB V12
Nova RR 12L3 hotmod
if you're having troubles finding time to run your fx, i can help
that's a lot of engine man. what is the best so far from your experience with them.
quick question about gearing. I was never good at it some how..lol... I always use factroy setup for my local track (small) it seem to work ok..
But..this comming up weekend I'm going to MMS (Mid West Series) in Mentor Ohio. I was wondering what gear shold I use?? It seem like it's a very big and wide open track. I just put the one way in my car. Oh..and I run regualr gear (NOT .8) .
So..what is the best option??
JP mod Mugen X12: Good mod. Good all the way around. Nothing spectacular, but good.
Murnan mod X12: This engine is not completely broken in, but shows lots of potential. Good power already. Idles well, good top and bottom. The only thing that is distressing, is that the fuel consumption is the highest of all my engines. I am going to continue to run this engine in until it loosens up a little and get my final evaluation.
JP FX T-03: I haven't run it yet.
Rody RB V12: The only thing I didn't like, was this engine seems to lack a touch of low end compared to the others. It is not bad, but feels slightly softer on the bottom. I run my clutch spring a little tighter with this one to try and compensate.
Nova NSR 12 hotmod: This engine rips. So far it is the best of all. Good bottom. So far the best top end. Good idle, mileage etc. I have more miles on this one than the others.
Nova RR12L3 hotmod: This is also fairly new, but I do have some running on this one. Good bottom. Better than average fuel mileage. Lacked a little on the top, but it is a torque built engine. I use taller gears with this engine vs all the others.
The differences between these mods are not monumental, but that is what I have found so far.
Just bought Max Power MX15 P7 to impress newbees next week
2.5cc - 7 ports
2.5cc - 7 ports
2.5cc - 7 ports
2.5cc - 7 ports
illegal motors are for newbees
Yeah...... newbees like me like fast things even illegal ones.... NP.
I have what you called "fast legal motors" : JP FX3 and FX5 but I'm not impress with its speed compare to .15 pro engines.
