Mugen MTX-4
#7216
Originally Posted by Scott Fisher
I didn't jump ship, they threw me overboard.
Now that's funny. It's lucky the "Good Ship Kyosho" happened by.
#7217
wieght on the car..........
What are people's thought about adding wieght to the car? Also, what does it do for handling when you put it in the front and in the rear?
#7218
Not front and rear, in the middle. NO CARBON BATTERY TRAYS. Not only do you have the ability to lower the overall C.G. you can also adjust front to rear weight balance. You would need to start kit stock to find out how Mugen built your little Snake Eater. Now if you would just point your mill towards something heavier I might have some money for ya. Think silver...
#7219
Need help.
I'm making overdrive calculator base on Excell for any cars with pulleys.
What is Number of Pulleys / Teeth in MTX4 ?
Front One Way / Front Gear Diff =
Front Center =
Front Side =
Rear Side =
Rear Center / Brake =
Rear Gear Diff =
Thanks !!!
Front Center =
Front Side =
Rear Side =
Rear Gear Diff =
Thanks !!!
#7220
Front
Front axle: 28
Front middle shaft: 18
Front side: 24
Rear
Rear side: 18
Rear middle shaft: 19
Rear axle: 41
Verify your numbers against Mugen's MTX-4 Overdrive Chart and you should be good to go.
Front axle: 28
Front side: 24
Rear
Rear side: 18
Rear axle: 41
#7221
Originally Posted by rmdhawaii
Front
Front axle: 28
Front side: 24
Rear
Rear side: 18
Rear axle: 41
Front axle: 28
Front side: 24
Rear
Rear side: 18
Rear axle: 41
Thanks, the excel its done.
I would like to check the math now. I need your inputs.
Given the number of pulleys above, am I correct to do the math like these ? :
A) Front Pulley Ratio : 28 / 18 = 1.5555
B) Side Pulley Ratio : 24 / 18 = 1.3333
C) Rear Pulley Ratio : 19 / 41 = 0.4634
D) Lets say 2mm split, Front Tires 63mm, Rear Tires 65mm : 63 / 65 = 0.9692
The overdrive ratio = A X B X C X D = 0.9314 ---> which is underdrive
AM I CORRECT ???
#7223
Originally Posted by sparksy
the supplied overdrive chart says for a 24T side pully, the overdrive with 63mm front and 65mm rear is 1.008
#7224
AM I CORRECT ???
AM I CORRECT ???
I'm not sure where you're going with D
E should be A * B
Then overdrive = (C * Rear Tire)/(E * Front tire)
Try that.
Special thanks to Eric Gebhard for explaining these formulas to me.
#7225
Flip C - It should be 41/19
E should be A * B
Try that.
E should be A * B
Try that.
EDIT : still not close to MTX4 overdrive ratio = 1.008 VS 1.07350
#7226
Has anyone out there tried the new Skyline Chassis? Durability, Tweek resistance? Quality of finish?
#7227
#7228
Can someone with good math check my approach to calculate overdrive ?
C) Rear Pulley Ratio : 41 / 19 = 2.1579
D) Lets say 2mm split : Front Tires 63mm and Rear Tires 65mm
E) Final Rear Ratio : 2.1579 x 65 = 140.2635
F) Final Front Ratio : (1.5555 x 1.3333) x 63 = 130.6557
Overdrive = 140.2635 / 130.6557 = 1.0735
MTX4 overdrive chart for 24T with 63 Front and 65 Rear = 1.008
#7229
Check your PM...
#7230
Check your PM...
Anyway........ I got it !!!!
I think here's HOW Mugen Seiki get the numbers ( I'm sure it's correct, but plz don't kill me if I'm not correct either )
E) Distance Front : (63 x 3.14159) / (1.5555 x 1.3333) = 95.4338
F) Distance Rear : (65 x 3.14159) / 2.1579 = 94.6306
Overdrive Ratio = 95.4338 / 94.6306 = 1.0085
Enjoy my Overdrive Calculator : I think it's correct.
