Mugen MTX-4
#6451
hmm
Originally Posted by blanks596
what are some must have hop ups? Looking to shave off a 1/2 second on my lap times. The only hop up I use on my car is the skyline 1pc motor mount. Motor and pipe are fine so I'm looking for other stuff that have proven themselves. Not looking to be pretty or bling bling, just looken to be fast and if so, ugly.
#6452
#6453
Originally Posted by BeBop
Guys Newbie here.
I just finish assembling my car and I want to know what tools besides a caliper do you use to measure the lenght of the shocks. Do you use any special tools. has anybody has use the team losi shock measuring tool? Its just when doing the shocks its always a challenge making sure that all 4 has the same lenghts.
#6455
Hey Sam, how much more does the 4mm weigh from the 3mm. What will the 4mm do better than the 3mm?
No more just watching races or being Nigel's pit pops, it's time to race
The 4mm chassis does not weight much more than the 3mm, due to it being milled out significantly on places where all the major component are and it is still stiffer than the 3mm chassis, you got to take a look,...... it looks really nice, I mean the machining done to it.
#6456
Front CVD's.
Ti screw set (upper side).
Besides this, you better go a grab a set of springs, rear roll bars and maybe the 4mm chassis, seems to be hot ticket for the people. Maybe your best hop-up is to practice and know your car and react to track changes. Isn't really needed a heavily hopped up car to be fast. Your best hop-up for being fast is to keep the car in top notch condition and pay attention to the bearings, is the most critical (and sometimes the most neglected part).
#6457
Originally Posted by Corse-R
Then, you may need very few parts, let's see..
Front CVD's.
Front CVD's.
#6458
Would you suggest lightening the car much? I'm only looking for an immediate 1/2 to 3/4 of a second. Traction is not an issue
Changing the screws for the Ti ones is the best weight lose you can do, you can shave up to 40 or 50grams in only one shot. Perfect.
#6459
Get the titanium pivot balls to reduce weight significantly.
#6460
Yeah Racing
Anyone use Yeah Racing parts? I'm thinking of getting the light flywheel from them. Decent? I'd prefer Mugen or Kawahara but neither have that option yet.
#6461
you can reduce half weight. Also can reduce more on mounting servo , i used alu screws
#6462
I've been asked a few times about the best tire split. I run 1-1.5mm and I've been told that that is too little. Not to second guess myself on this, but what works best? anybody?
#6463
Hello Guys,
I have a couple questions about my Mugen MTX-4 that I hope someone can help me with. Does adding caster (the tilt of the front hubs) to the front increase or decrease steering? Also, the inserts that go in the rear of the car, the two plastic pieces that hold the hinge pins, how does changing there angle affect the handling of the car? Is this the roll center adjustment? or rear caster adjustment?
#6464
On the RRR side of the house, everyone recommends starting with a 2mm split. I adjust accordingly based on wear, as our track layout always changes from race-to-race.
#6465
Originally Posted by vulso
Hello Guys,
