Mugen MTX-4
#6031
Originally Posted by Yome
Hello,
i'm new to RC world. I wondered if the 3racing universals for MTX4 are anygood.
They cost a lot less the the mugen original ones.
Regards,
Regards,
#6034
Originally Posted by blanks596
Has anyone ever began there races, whether qualifying or main, with tires that are 53mm or less? Right now I have a set of tires that are 53 front and 54mm rear. I know this may be questionable for a 15 min main, but what about for a 5 min qualifier?
#6036
Originally Posted by Tag
well it's also depending on how you setup your shocks, i guess it's okay to run it down to the bone as long as you maintain acceptable ride heights or it will hinge your car handling
#6037
Originally Posted by wallyedmonds
idono what size they where but they where very close to the rim,i like to get my moneys worth LOL
Exactly I hate wasting tires. Lately I've been running approximately 55mm front and 56.5mm rears and then not using them anymore, but I have a bunch of 53 and 54mm tires so I think I'll make use of them. Set up is not a problem, I just dont want the tires shred apart during a race.
#6038
hey guys, just tweaking my chassis, and on default set up sheet it saids track width is 200 at the back
can u check the photos and see if its right. for example, should the dogbone be stickin that far out??
and do i adjust track width by them screws near the wheel
thanks
thanks
#6039
thanks
thanks
BTW: With the car at 199mm you're pretty confident you will not get problems with techs due to a 'too wide car' and the difference is almost negligible.
#6040
ya it looks like your track is too wide and for the dogbones i use 1 o ring on the wheel end and fuel tubing on the diff side oh and how are you doing the track how do you measure it where on the tires.
#6041
I wonder how are mugen pilots doing in brisbane ?
#6042
http://www.200mmifmarworlds.com/Default.aspx?tabid=329
#6043
thanks
thanks
#6044
Originally Posted by Nitro$junkie
yeah they are great for the price
i brought a skyline racing set for back up i didnt know how the 3Racing ones would hold up. But havnt needed them yet and its been 4 months run time
#6045
This has probably been covered before, but is it fairly usual for the MTX4 to eject dogbones when you give it a good whack to the front end? I ejected a bone and lost an outdrive today. Shame too cause the car was fast.
Also how long are most of you getting out of your bearings? One of my front small stub axle bearings is already toast. It was the one I gave a whack to, perhaps it sustained some damage. Funny thing is I never killed a R40 bearing in 2 1/2 years...........
