Old 01-20-2006, 01:18 AM   #3121
asw7576's Avatar
other mishaps :
1. Mechanic turn on the receiver, start the engine, but forget to connect the throttle linkage.
2. low batt situation
3. throttle linkage break away after impact with another car.
What do you mean with "something u din want 9 mths later?? "
Old 01-20-2006, 02:32 AM   #3122
chippy's Avatar
Default 9 months later
Because you didn't use a rubber!!!!!!!!!! Band LOL
chippy is offline   Reply With Quote
Old 01-20-2006, 02:41 AM   #3123
asw7576's Avatar
I'm getting confused ..... In the begining I already wrote "Yes, I use rubber too whenever possible".
OK, enough of rubber band things.....
3racing hop up are out yet ?
Old 01-20-2006, 04:23 AM   #3124
Corse-R's Avatar
Originally Posted by dg8one
SOMETHING LIKE THIS BEEN USING RUBBER BAND SINCE I START RACING GAS
In fact, there was a rule that enforced a mechanical carb closing device for just in the case you got a blackout on your receiver pack (is that rule still in the rulebook?) besides a failsafe, NOTHING than a return spring or a rubber band can close your carb if you run out of juice and avoids rundowns and full throttle smashess to the nearest concrete wall (don't know why, but a car without Rx battery, loves them. )
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-20-2006, 05:47 AM   #3125
dg8one's Avatar
never had a chicken run
i alway take my time to build my car and recheck everything so i dont have to runin to any kind of trouble
Member of the CHEATERS CLUB
TEAM KAMIKAZE(MARYLAND CHAPTER)
TOKWA'T BABOY LTD
dg8one is offline   Reply With Quote
Old 01-21-2006, 01:40 PM   #3126
asw7576's Avatar
How often do you guys rebuild the car ?
I set my service interval @ 3 to 4 months of use, complete with cleaning & polishing, and of course including the hardest part : bearings cleaning + re-oiling.
Old 01-21-2006, 02:05 PM   #3127
Chris West's Avatar
Send a message via MSN to Chris West
between each meeting to make sure there are no broken bearings and to make sure the car is in race conditon so it wont crap out in a race, everyone should do this I see some people at the club and their cars are covered in crap and they dont usually do thatt well at all
MUGEN SEIKI | NINJA | SANWA
Chris West is offline   Reply With Quote
Old 01-21-2006, 02:09 PM   #3128
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Same here, before every race. Already I found some things wrong, that being the belts. Some of the side belt teeth are starting to crack. This is after only one race.
I reccomend everyone use the rubber belts. Also, the V-One RRR side belt will fit on the MTX-4.
Racing4Evo is offline   Reply With Quote
Old 01-21-2006, 02:15 PM   #3129
Chris West's Avatar
Same here, I use the rubber belts aswell last longer and makes the drivetrain more free
I also noticed that the standard belts started cracking but only slightly after a couple af race's and on one of the standard belt's about half the teeth ripped of the belt in a 20 min A final. lucky I finished the race in the podium.
the urethane belts don't break the teeth just dissapear.
Old 01-21-2006, 10:30 PM   #3130
asw7576's Avatar
I wish I have enough time to rebuild the car before every race meeting. I have too many cars to take care.
My friend tell me to have only 1 car each for GP and EP, so I have enough time to take care.
I can't believe you guys rebuild the car before every race meetings.
Old 01-21-2006, 10:43 PM   #3131
ntc3freak's Avatar
god i love ur avatar
ntc3freak is offline   Reply With Quote
Old 01-21-2006, 11:45 PM   #3132
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I have almost 3 gallons of fuel on my car. I just had to replace the side belt which is rubber. I replaced the front and rear urethane belts just because I have a 60 minute main to run tomorrow. They both look brand new. I don't know if you do this, but I never use denatured alcohol, or anything else for that matter when cleaning my car. I just use compressed air. I put on a set of the rubber belts as they definitely roll better than the urethane belts.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-22-2006, 12:17 AM   #3133
asw7576's Avatar
I clean my belts with Armour All ( white liquid ). I haven't change my belts since new. I wipe the belt after race...... it's quite hard to clean the front and middle, but do able.
It's almost 1 years old now ( mtx3 ).
Old 01-22-2006, 12:51 AM   #3134
Chris West's Avatar
I take my belts off before I clean my car with brake cleaner and air compressor, so its not any chemicals that are causing my belts to crack. It was mostly the side belt (gone through 2 belts) and ive done one front belt aswell but ive never gone through a rear belt on either of my cars ive just replaced them just in case. Its not my pulleys either I keep them clean as (no crap between each teeth).
Scott wats the surface like that you race on?
Chris
Old 01-22-2006, 09:26 AM   #3135
I have only raced on prepared surfaces. The only tracks that my MTX4 have been on so far are the Silver Bowl Raceway (las vegas), Revelation Raceway and Crystal Park Raceway (both in southern california). As I said, they are all clean and prepared dedicated raceways. Perhaps a dirtier track is causing your belt cracking? It doesn't sound like you are having any major issues, as belts do wear out no matter what you do.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
