Old 01-22-2006, 11:31 PM   #3151
Vinyard's Avatar
Originally Posted by Tag
whats your opinion on alum side pully ? my 24T went out on me today and i am thinking about if i should go with alum or stay with plastic. some said stay with plastic as alum does not last as long , what do you think
Also some had the alum pulleys wore out faster.. as the teeth gets sharper your belts suffers.
I am sticking with the plastics.
Vinyard is offline   Reply With Quote
Old 01-23-2006, 05:06 AM   #3152
Stupid2's Avatar
has anyone used the 3racing 4mm chassis yet ?
Stupid2 is offline   Reply With Quote
Old 01-23-2006, 06:42 AM   #3153
GrandeGixxer's Avatar
Trader Rating: 15 (100%+)
Scott, good run at the WWUP. I wish I could have made it but oh well. We are going to try and make it out for the Paris race. If everything works out, I will be there.
Joe Cude
Mugen MBX-7R Mugen MTX-6R Mugen MTC-1 Mugen MRX-6 Mugen MST-1 Tamiya Euro Truck
GrandeGixxer is offline   Reply With Quote
Old 01-23-2006, 09:46 AM   #3154
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
Thanks.... Glad to hear you might come out here in October.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 01-23-2006, 09:46 AM   #3155
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Default Skyline Universals
Just want to give a heads up on the the Skyline universals. I've had some pretty nasty crashes already with my car where I ripped the front lower arm and shock off the car with no damage to the universals. They're even bent. They're holding up great. I can't say if it's better than the Mugen universals since I haven't tried them but from my experience with Kyosho universals on my V-One RRR they are more durable. Maybe someone can relate the universals in some way with that information.
Racing4Evo is offline   Reply With Quote
Old 01-23-2006, 07:13 PM   #3156
Originally Posted by Scott Fisher
T0268 front belt (rubber)
T0269 rear belt (rubber)
I just found them in the option sheet. Thanks
Also I heard that the first kits came with two side belts. Are they only selling one because my 4 only came with one side belt? The #'s on my side belt are 27 then a space then R5A and a space then 030. The kit # is T0267. Is there another one that you are using?
THE DOCTOR is offline   Reply With Quote
Old 01-23-2006, 07:24 PM   #3157
Derby Bros Racing's Avatar
hi peter,
i'm want to try the skyline universals. right now i have the regular mugen in the front and dogbones in the rear. but i would like to get both the front and rear skyline to save on shipping cost. any word on when you will get the rears available?
thanks
Derby Bros Racing is offline   Reply With Quote
Old 01-23-2006, 08:20 PM   #3158
Some of what I going to say I know for fact, some is what I think.
I got one of the first kits that had two side belts in it. It had the T0267 urethane belt, and the T0270 rubber belt. My kit also came with two side pulleys. One had 23teeth and the other had 24 teeth. The T0270 belt came in a supplemental parts bag that had an instruction in it to use the 24 tooth side pulley and to use the rubber belt that was in that extra bag. The rubber belt is longer than the urethane belt. When using a 23 tooth side pulley you need to run aprox 6.5mm tire split to have zero overdrive. Using a 24 tooth pulley you run aprox 2.5mm tire split to have zero overdrive. Using a 25 tooth pulley you run aprox zero split to have zero overdrive. Using a 24 tooth pulley, the urethane belt, fits over the pulleys, but rubs on the exhaust manifold. I have not tried the 23 tooth pulley because I don't want to run such a gigantic tire split. I think Mugen figured that out as well, so they just said to use the 24 tooth pulley and included the rubber belt which is longer. Because it is longer you put the belt tensioner down far which then clears the exhaust manifold. I have not tried it, but my guess is that the rubber belt will fit with the 25 tooth pulley as well. I also think that more people will use the 24 or 25 tooth pulleys. I don't even know if Mugen sells the urethane side belt, because like I said it only can be used with the 23 tooth pulley that probably nobody will use.
I am only using the T0270 rubber belt.
Old 01-24-2006, 12:58 AM   #3159
Racing4Evo's Avatar
Originally Posted by Jo Gutierrez
hi peter,
thanks
Hi Joe, they should have them around next week. I will let you and everyone know when they are available since I need a set for myself.
Old 01-24-2006, 01:00 AM   #3160
Racing4Evo's Avatar
Skyline is also considering an aftermarket chassis for the car. Maybe a stiffer one to take out the twitchy nature of the car.
Old 01-24-2006, 07:03 AM   #3161
jag
jag's Avatar
Default Side Brace
Is anybody working on a side brace for the exhaust side? I have heard (don't know for sure) that the chassis tweaks easily and not having a brace on both side may contribute to this. It does not look like an easy piece to make.
Any opinions on this?
jag is offline   Reply With Quote
Old 01-24-2006, 09:48 AM   #3162
Corse-R's Avatar
Have you tried the car yet? Mine doesn't need a chassis brace around the exhaust. The MTX3 didn't carried a chasis brace there and the same for 4.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 01-24-2006, 10:55 AM   #3163
carkillaii's Avatar
For you MUGEN drivers , Darin brought it home , Las Vegas Winter WindUp 06
PS he changed all 8 batteries during the race in this pitstop
the man is good
carkillaii is offline   Reply With Quote
Old 01-24-2006, 11:15 AM   #3164
Question for you all. How much intrest would there be in a chassis of this type for the MTX4. The picture is an RRR chassis, but with enough intrest I am sure one could be made for the 4.
http://kfactoryracing.com/BIG/K%20Factory/K19/K1912.jpg
Motorman2 is offline   Reply With Quote
Old 01-24-2006, 11:52 AM   #3165
asw7576's Avatar
I'm not sure I would like to buy that...... If you look closely the chassis has less meat on the side area, especially near the engine area. The chassis might bent at impacts...... not beefy.
MUGEN MBX5R/MUGEN MBX5T PROSPEC/TRAXXAS RACE REVO Jason Halvorson R/C Items: For Sale/Trade 14 01-12-2008 10:32 AM
USA's Most Wanted FOR SALE Mugen MBX5R,Losi 8 comp, and Mugen MBX5T Prospec Truggy nobike R/C Items: For Sale/Trade 69 04-28-2007 07:45 PM
Another MTX3 prospec w lots of parts and an optional Mugen X12 w Mugen pipe Scott Fisher R/C Items: For Sale/Trade 11 11-21-2005 05:45 PM
drake xxx nt and mugen mst-1+extras......Looking for a kanai 2 or maybe mugen buggy [email protected] R/C Items: For Sale/Trade 5 06-30-2003 09:31 PM
