V-ONE S Thread
#4186
Cut half the front window out, on the engine side, and the same in the back window...
Other wise you WILL cook your motor...
Just make all the corners rounded not straight...
#4187
is those round circles more effective?
#4188
Take a drill with a 1cm drill piece in it...
Drill a hole in the top corner of the front window on the engine side, do one at the bottom...
now do one at the top of the window, in the middle, and now at the bottom in the same line...
Now join it all up so its basically a square but with rounded corners
#4189
but isnt the circle better or worst? why people's opinion differ?
#4190
the circle is stronger design, but flows about 3/4 of what the square can...
that why a square with rounded corners is the best...
And a cut out window actually lowers drag levels on the front of the car, but can increase them on the rear...
but all round, its the same, except you get a cooler running engine, that is more reliable
#4191
Oh....... i get it... im enlightened.. thanks dude
#4192
Also, just to let you all know...
I might be away for about 3-4 weeks off here...
I have half yearly exams coming up, and need to study..
ill pop in everynow and then
#4193
Good Luch V-One S
#4194
Originally posted by dazza
Good Luck V-One S
Good Luck V-One S
#4195
I mean LUCK
#4196
yea, the harder you work, the luckier you get.
#4197
Originally posted by Sp Racer
If you think that you need to modify the GS15R to get more power from it, then I'll bet you still haven't got the best out of it yet...
Got a tuned pipe on it?
1/do you think any tune pipe will do? like the carlen ones on rcmart for only $29 USD.
2/also do i have to upgrade the header as well? or just the pipe will do?
3/also with pipes can any good tune pipe be used with any good motor?
and also no i havent done the clutch upgrade UM210 either will do this once i get my mind decided on wether i will be upgrading soon or not.
so far i've only brought these as extras.
2 speed
blue head
alloy threaded shocks (as i run foams)
fail safe
extra diff gears on F+R
And ben with concerns of me having more skills than the FW-05s driver then no. i believe both cars are pretty much same speed. as on the straights we are dead even. Also my 2 speed is weird sometimes it kicks in some times it doesnt and i believe at that time racing against him it didnt kick in at all or i'd get him on the long straights. hes running single speed.
#4198
Hey people
My Mates got a VoneS and wants to know what he has to get to put a SG Crank type engine in it. We got the pipe and the Engine Mounts all we need is a Part # for a Clutch that will fit on a SG Crank and go into a VoneS with the same type of gear mesh.
PLZ HELP
PLZ HELP
#4199
hey guys
today i went to the rc tracks and was driving around having a little race with this other dude and after 2 tanks my car didnt move, first gear was completely stripped can i just buy a first gear without having to buy the 2 speed set?
#4200
Originally posted by PhiLLaY
hey guys
hey guys
Cheers
