GT 1/8 Scale Rules and Setup Sharing
#617
if anyone is thinking about it
http://www.rctech.net/forum/r-c-item...8-gt-artr.html
#618
What a joke these ROAR rules are.
#619
Ty i have a set of 40e's,45e's and BETA test ( i have no idea what they are, but i know they did not like 150* track temps!) all of them are balanced and on orange ROK's, and have been in ziplock bags so they are in excellent condition! hit me up i will give you a good deal on all of them.
#622
Just out of curiosity. As I sit here and rebuild my GT for the 2014 season I find myself looking for options to make the car that much better. One thing I have heard about is ceramic bearings like the ones from Acer Racing or Boca Bearings. Now I understand the theory and know their use in racing bikes and so on but my question is do these same benefits apply to the 8th scale RC world. The only cons I have heard is if they fail they fail hard resulting in a DNF and they aren't cheap like the steel bearings. Pros are less resistance resulting in a more efficient driver train.
What are your guys thoughts? Ceramics in a GT? Curious to see the different thoughts between Factory racers to just the hobbyists as many of the opinions I have heard deal with this.
#624
Makes perfect sense to me, Ceramic the drivetrain minus the hubs for impact protection. Thanks for the reply!
#625
I use only Ceramic bearings on clutch bell and center diff or 2speed. These bearings are under consistent pressure and near consistent heat source, they do provide more efficient drive train results in these areas. Everywhere else a good quality steel is all that is needed.
Just check them often (both ceramic & steel) a small tip is after a run feel the cvds, I have noticed that if cvd is extremely hot it has usually been from a bad or going bad bearing.
I check, clean and relube them as regularly as possible. Don't wait till it actually seizes up will do more damage then you think.
#626
You will only gain a tiny bit with ceramics if you are a toplevel driver. If you aren't just do not think about it.
#628
but.... people are easy fooled with the way of thinking that performance can be bought. Most of the time these people are even not capable to setup a clutch or finetune their engine to the best performance.
#629
Are we talking Semi-ceramics with ceramic balls or are we talking about the full, All ceramic bearings you can get?
I know some very high quality semi or part ceramic bearings are very expensive, almost as expensive as the fully ceramic but because of the high quality S steel or chrome are also very impact resistant.
Fully agree on one thing. With ceramic they do tend to fail catastrophicly!
Regards
BM
Regards
BM
