Serpent Cobra GT >
Serpent Cobra GT
Like Tree99Likes
Serpent Cobra GT
Old 08-25-2017, 08:05 PM
  #2356
Trader Rating: 37 (100%+)
Ok thanks get them coming!!!
Top Notch likes this.
DKB243 is offline
Old 08-25-2017, 09:50 PM
  #2357
And will these parts be available in an upgrade kit altogether or only individually?
Cilal is offline
Old 08-25-2017, 10:41 PM
  #2358
Cilal is offline
Old 08-26-2017, 12:31 AM
  #2359
dan_vector's Avatar
Trader Rating: 27 (100%+)
I'm not sure but thinking about the previous upgrades to the car they did release the 3.0 suspension upgrade as a kit. So perhaps this update will be as well.
This update is a really big step. I'm .4 secs per lap faster at my local track with the update on. I had to go a step harder on the springs as well I am now running the extra hard and the extra extra hard springs (the 2 hardest grades). It is really fantastic.
MantisWorx likes this.
dan_vector is offline
Old 08-26-2017, 01:53 AM
  #2360
Good to hear.
Are you running the springs same all round or XXHard front and XHard rear?
Cilal is offline
Old 08-26-2017, 07:39 AM
  #2361
dan_vector's Avatar
Good to hear.
Most of the time same all round but will try a grade softer on the front if I need more steering sometimes but 95% of the time same spring front and rear.
Old 08-29-2017, 09:19 AM
  #2362
Trader Rating: 17 (100%+)
Serpent released the 600985 suspension upgrade as a SET (for now)......anyone has a setup for that.?
Solara is offline
Old 08-29-2017, 09:38 AM
  #2363
dan_vector's Avatar
Yep. I've been running 3.1 standard for a while now. To be honest most of the setup has remained the same just harder dampening and springs. Now up to 1000 - 1200 cst oil and the 39.5 and 42 lbs springs and shocks in the lowest or 2nd from bottom hole in the tower front and rear depending on the track.
All in all its a fantastic update to the 3.0 GT car!
Old 08-29-2017, 10:31 AM
  #2364
Excellent.....just ordered the upgrade and will test it in 3 weeks.
Also.......is that the latest upgrade for the GT3.0? Any other options that was tested from Serpent?
Solara is offline
Old 08-29-2017, 10:37 AM
  #2365
dan_vector's Avatar
That's pretty much it. Oh and the hard arms are worth getting as well as those just sharpen up the handling a bit. With the hard arms in the rear it widens the track a bit. I didn't like the loss of rotation it caused and so filled in the holes where the hub carrier mounts with plastic grub screws and re-drilled the hole in the 'old' position returning the track to the previous width.
There is a new vented steel clutch bell on the way as well I believe.
Old 08-30-2017, 06:23 AM
  #2366
Hi Dan, I bought the upgrade piece by piece as you stated in some of your replies before, do you know if the insert that goes inside the shock stand off comes with one of the list parts you put or it has another part number?
Thank you
pepegrillo89 is offline
Old 08-30-2017, 07:01 AM
  #2367
dan_vector's Avatar
Thank you
Do you mean 600118?
You use the existing parts from the standard kit.
Old 08-30-2017, 07:08 AM
  #2368
Great thank you very much!!!!
Old 08-30-2017, 07:55 AM
  #2369
dan_vector's Avatar
Enjoy the new parts. The car is awesome!!
Old 08-30-2017, 10:41 AM
  #2370
GT front tire, inside edge wearing problem.................this is a on going issue for me, I think.....it is my driving style, I brake heavily and punch launch heavily while racing. Car is GT3.0 using Paolo or other's latest setup...tires, does not really matter, latest Sweep or old Alpha, all are wearing the inside of the front tires.....from 40s, 45, to 50s....the tires can only survive are the 50s and 55s after 1 hour main. However, running 50s or 55s just not going to be fast.
The reason I asked this is I don't see others have the same issue...especially on the new style tires from Sweep or others....all my tires are drilled holes for ventilation and I know the new SWEEP are pre drilled holes all over. Will that solve the problem that I have..?
This is the only issue that I have on GT...really hate to see 2 run tires (5 minutes run each) and they are trash.....
Solara is offline
