Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012
#1172
If you use these http://www.serpent.com/product/804277/ with these http://www.serpent.com/product/804278/ its going to make the car rotate more. Have you tried setting the rear shocks more vertical? You can also try putting shims under the rear camber link on the hub, 1mm at a time, that will make the car rotate more
#1174
New 748wc edition diffs and ratios in 747
For those that want to try the new 748wc diffs and new internal ratio, you can!
You will need:
804390. Front diff
804391. Rear diff
804396. Pulley set
804349 side belt (the old 748 side belt which is a little longer than the stock 747 belt. The new 748 belt is too long!)
For correct side belt tension you might need to mount the tensionner under the radio tray.
You will need:
804390. Front diff
804391. Rear diff
804396. Pulley set
#1175
Or for those who want to use old diffs (747) the big 33T pulley has perfect fit in front diff - just replace standard 35T front diff pulley
with one from new pulley set - 804396 or 804398, side belt from old 748.
