Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012 >
Old 02-27-2015, 07:58 AM
  #1141
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
Originally Posted by snuvet75
Dan, my problem is gears are too close to each other. Raising pinions will worsen the problem.
We had the same issues fitting Sirio's in the 733. Shimmed the bottom of the engine mounts. Problem solved. Give it a shot before pulling out the dremel
Serpent-Dan is offline
Old 02-27-2015, 01:45 PM
  #1142
snuvet75's Avatar
Trader Rating: 16 (94%+)
Thanks Dan but again, how would it solve the problem? When you look at the pinions and 2 speed gears, the pinions meet the 2 speed gears at toward the bottom. If you raise the mount, pinions would be higher meeting the 2 speed at its bigger diameter creating tighter mesh. So I don't understand the logic.
Attached Thumbnails Serpent 747 1/10 200mm touring @Nurnberg Toy Fair 2012-capture.jpg
snuvet75 is offline
Old 02-27-2015, 07:16 PM
  #1143
dan_vector's Avatar
Trader Rating: 27 (100%+)
That was my point. The only way I could achieve extra clearance was to enlarge the mountsng holes very slightly
dan_vector is offline
Old 02-27-2015, 08:11 PM
  #1144
snuvet75's Avatar
Which mounting holes, Dan?? bottom or top holes in engine mount? holes on chassis? The holes on chassis seems to be only way to do it to me since any modification on holes on engine mount will greatly compromise the stability of the engine mount. Correct me if I'm wrong.
I decided not to do it anyway since it fits to my 748 fine and I'm planning to run the engine with 748. It's just that I have local "not serious" race this weekend where I run 747 and figured I'd break in the engine while it's on 747 and then would change it to my normal "I don't care" engine to Ison .12 to run the race. That way when I go to a competitive track next weekend, I can save time breaking in the Picco.
snuvet75 is offline
Old 02-27-2015, 10:39 PM
  #1145
dan_vector's Avatar
The holes in the engine itself mounting lugs. Anyway no issues as you've got a work around.
Old 04-11-2015, 07:11 PM
  #1146
racerx1920's Avatar
Trader Rating: 218 (100%+)
just picked up a 747 and i want to run a life or lipo receiver pack. what are people running?
racerx1920 is offline
Old 04-12-2015, 02:40 AM
  #1147
dan_vector's Avatar
Life - Reedy pack http://www.reedypower.com/products/details/305/
Lipo - Xceed pack http://www.xceedrc.com/product/105001
Old 04-12-2015, 02:49 AM
  #1148
Evo 13's Avatar
I had the Xceed lipo in mine. Fits well!
Evo 13 is offline
Old 04-12-2015, 01:58 PM
  #1149
snuvet75's Avatar
Do u know the weight of the pack?
snuvet75 is offline
Old 04-12-2015, 03:53 PM
  #1150
dan_vector's Avatar
Not off hand but it is the lightest pack of that capacity that I know of.
Old 04-12-2015, 04:21 PM
  #1151
el salvador's Avatar
The Reedy LiFe pack weighs 70 grams.
The Exceed LiPo weighs 60 grams.
el salvador is offline
Old 04-13-2015, 06:56 PM
  #1152
dan_vector's Avatar
Thanks. Useful info.
Old 04-14-2015, 09:47 AM
  #1153
snuvet75's Avatar
I kind of figured Xceed one would weigh less than my Reedy Life. I will get high voltage servos next time so I can use Lipo.
snuvet75 is offline
  #1154
snuvet75's Avatar
http://www.rctech.net/forum/r-c-item...tro-sedan.html
Selling 747 if anybody's interested.
snuvet75 is offline
Old 04-14-2015, 05:32 PM
  #1155
Evo 13's Avatar
I have no idea, I sold my 747 months ago.
Evo 13 is offline
