NEW HB comp touring >
NEW HB comp touring
Like Tree2Likes
NEW HB comp touring
Old 08-13-2013, 06:52 PM
  #316
KMW
KMW's Avatar
Originally Posted by Bundy_Bear
A little weekend work on Richards R10 last night and we have managed to drop just over 50grams out of it with new Capricorn front and rear diffs, Capricorn rear alloy drive shafts and KM Racing outdrives and drives hexes.
Still room for more improvement with changing to a LiFe battery from the NMH pack and a few other goodies I have in mind
Is this now a Hot Cap... Use to have a Cappy-Ray that was fast
Andrew
Nice work. I have a Hotcap as well. After the build mine was very light. The number below is with a 60g brass battery tray and Capricorn LiFe battery. I add another 40g of tungsten weights to make the car 1625g with body.
KMW is offline
Old 08-14-2013, 04:35 PM
  #317
richardc7696's Avatar
Nice Job! Besides the diffs and pulleys can you tell us which other bits you are using?
richardc7696 is offline
Old 08-15-2013, 09:50 AM
  #318
KMW
KMW's Avatar
The other parts that shaved some weight are Ti screws, Ti front CVD shafts, Ti 2-speed holder, Capricorn lightweight uniball kit, Capricorn middle layshaft, Capricorn clutch, Xray rear CVD shafts, and Xray lightweight one-way and 2nd gear carriers.
KMW is offline
Old 08-15-2013, 07:02 PM
  #319
1evo RRR Driver's Avatar
Damn Woods how did u know all that stuff was interchangeable!!! (2speed stuff)
1evo RRR Driver is offline
Old 08-17-2013, 12:33 AM
  #320
Bundy_Bear's Avatar
Is the Capricorn middle layshaft from the C01 or the C02?
Andrew
Bundy_Bear is offline
Old 08-17-2013, 02:53 PM
  #321
Tabushi's Avatar
Guys do you know any fuel tank that may fit as alternative to stock ?
Tabushi is offline
Old 08-17-2013, 09:48 PM
  #322
KMW
KMW's Avatar
Andrew
Either one, they are the same as far as I know.
KMW is offline
Old 08-18-2013, 05:34 PM
  #323
Bundy_Bear's Avatar
Thank you, I had to custom make a spacer between the 25t pulley and the layshaft holder... Only down side is you can no longer use the standard receiver position as the plate is now in the way of the side belt.
I see you are also using the Capricorn ball ends, did you need to change the ballends as well or they work with the standard HB ones? I am pretty sure you changed them as they look to be silver rather then black... but just wanted to check.
Thanks in advance
Andrew
Old 08-19-2013, 11:07 AM
  #324
Ec1
Ec1's Avatar
www.ghea.se will make a titanium middleshaft/spacer to be able to use xray/capricorn pullies. I raced it this weekend at our Localrace with great resault. Think they will put it in their webshop the following days. // roland
Ec1 is offline
Old 08-19-2013, 05:43 PM
  #325
Bundy_Bear's Avatar
Watch out for the flywheel nut, keep having it come loose slightly on both Richards motors. Wonder if that is the reason the clutchbell play keeps changing or is that a wearing clutchpad...
Andrew
Old 08-22-2013, 03:51 AM
  #326
Bundy_Bear's Avatar
http://www.youtube.com/watch?v=e7KgxsbK3kk
Old 08-22-2013, 04:11 AM
  #327
Bundy_Bear's Avatar
I'll see if Richard can post a photo soon, but keep en eye on the pins on the driveshafts that sit in the diffs. He has just had to replace the front ones as one side has of the pin has worn flat.
Old 08-22-2013, 08:05 AM
  #328
chromie's Avatar
where do you all get parts for this car ? I cannot find any plastic arms anywhere.
chromie is offline
Old 08-22-2013, 11:14 AM
  #329
Adrean's Avatar
Tower Hobbies has some plastic parts in stock !
Adrean is offline
Old 08-22-2013, 04:29 PM
  #330
Bundy_Bear's Avatar
Depending on where you are located Tower Hobbies or A Main are your best bet. We are in Australia and RChobbies in Sydney have parts listed. But we bought multiple kits and this has kept us going for most of the year so far.
Andrew
