Kyosho v-one rrr
#1471
Originally posted by jeffreylin
I don't think it's the bearing. I hear glitching with the M8 here and there. I think you should just run the KO stuff.
BTW, my FW05R was dialed Saturday night. I am going to try running that car again.
To Alex- I told you so!
#1472
Originally posted by Racing4Evo
Dude, the radio is brand new! I just want to run the KO for electric. It just feels more suited to electric for me. If all else fails I will go back to it.
#1473
When are you coming back? Ken ran the FW last time and he looked better than usual.
#1474
You should've seen my chassis! I had like 30 deg. of front kickup, more than a buggy . Alex said he could bend it back and ended up breaking it.
VZ201-1 V-One RRR Steering Knuckle 1 degree
VZ201-2 V-One RRR Steering Knuckle 2 degree
VZW208 V-One RRR FRP battery plate
VZW211 Titanium diff bevel gear shaft
VZW212 V-One RRR FRP middle plate (belt tensioner holder)
VZW213 V-One RRR Lightweight Pinion Holder
VZ230B Revised RRR upper deck.
Time to place an order!
#1475
Yeah I'm going to get the WC edition as a second car but I wil have to get those titanium bits. Is that the diff outdrives? Those 2 degree hubs are just what I'm looking for too!
#1476
Stay tuned for some cool hop ups from Skyline Jeff!
#1477
#1478
#1479
What's so funny? Seriously, the best I've seen him drive in a while.
#1480
No, not the outdrives but the shafts inside the diff that holds the bevel gears. Reduces rotating mass.
#1481
Hey, I am building my RRR right now. I'm on step 26, building the two speed, but the second gear housing is real tight over the plastic changer. Has anyone had this problem or know how to fix it?
#1482
Oh, I don't need those. We are all having problems with the outdrives and notching. Some more serious than others. You can just flip the diff over after one side notches but it's only a psuedo fix.
Speaking of the CVDs, you should check for the wear on the wheel shaft side as well. You might have to re-assemble the CVD and put the pin in the other set of holes because of notching.
#1483
You might have the grub screws tightened too much. If it's not excessive, it will go away after a few tanks of running. Just give the car time to break in. The second gear housing built in to the actual spur gear is one of my gripes about the car, the other being the tank of course.
#1484
Just checked the site. Could this be the first sign of the rumoured Kyosho and Great Planes split? I HOPE SO!
#1485
Cheers
