Kyosho v-one rrr
#9751
From experience, when I ran ALL aluminum pullies in the past, I went through alot of belts. After a awaile, the teeth on the pullies sharpen due to friction from the belt and the aluminum pullies. The reason why I only run the small drive pulley in the rear is because that's what came with the car. I know there's a plastic rear pulley available, but you would have to run the brake adaptor with the old style brake. You can run the aluminum pullies if you want to go through belts like I did. Its definately a " bling factor " in my opinion. To each, his own.
#9752
I was just wondering thats all, over here have no choice really, after cleaning out the track and sugaring it down, the track within the next 30min gets dusty again from inconsistent weather, I find that the plastic pulleys would chew up faster, therefore the only workaroud are the alu pullies.
I was just wondering if anyone would sense any difference in throttle response?
#9753
I agree with that the only alu pully is the small drive pully...
#9754
A few Questions
Hi all,
A few Question below that shall definably put me in the learners group . Any help on them would be awesome.
1) What is offset in knuckle arm , driver washer and tires ? And what are there pro's and con's ?
2) what is a better clutch system for the RRR WC EVO ? Since there are a few on the market.
3) i Cant Get a Right camber degree so my tire burn evenly,(running anti clock wise on rough medium traction track) What is the rule in setting cambeR?
Regards
Alex
V one RRR WC evo
V one RRR WC
O.S Speed , O.s Tz .12
Regards
Alex
V one RRR WC evo
V one RRR WC
#9755
ccrcraceway, I know I posted it somewhere, just do a thread search or on this forum for hudy pdf handbook or if someone would be kind enough to post the link.
It will give near all the information you need to know about rc onroad car setup.
#9756
Location: Costa Del Sol, Marbella, Spain www.bradir.net
springs
hey guys! im still using the old RRR shocks and would like to know if the 720 springs will fit?
#9758
Hello,
I'm trying to figure out whcih battery pack I need for the receiver. The manual says use only 71162 6V X-FORCE. Is that the one I have to use?
#9764
First time running a diff I'm hooked
My RRR had a good day out at the local track today car handle very well considering it was the first time running a front diffI'm hooked, the car was so easy to drive compared to a spool. To me its like having a oneway with 4 wheel braking, well I just wanted to share with all of the proud RRR onwers around the world....GO FAST and don't look back.
#9765
ya man...if i have the extra cash, will get one too
