Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 05-27-2006, 09:23 PM
  #7021
litespeed-dom's Avatar
Originally Posted by maskedrider
I just noticed the pivot balls are silver...
Dom
litespeed-dom is offline
Old 05-27-2006, 09:27 PM
  #7022
rmdhawaii's Avatar
Dom
At the moment, my current line of thinking is, "better to bend, than to break." It's a point that someone brought up in the UE/X thead about Ti.
rmdhawaii is offline
Old 05-27-2006, 09:28 PM
  #7023
Racing4Evo's Avatar
I think the silver ones are the same as the Stock V-One RRR and the FW-05 cars. Only the WCE and the Evolva have the black ones which are a lot stronger.
Racing4Evo is offline
  #7024
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by rmdhawaii
What weight oil are you using and how high did you fill the diff oil? Only up to the top of the bevel shafts, right?
I'm useing kit oil...Not over fill...I took out the shims behind the large bevel and much better but the out drive is too loose is slide in and out the diff case ..you can pull the out drive in and out ... Dang can't find my instruction
OVA is offline
Old 05-27-2006, 09:30 PM
  #7025
Racing4Evo's Avatar
But on the counterpoint, it's easier to discover a broken part than a bent one. Sometimes I didn't even know I had a bent piviotball until I was trying to adjust my camber.
Old 05-27-2006, 09:31 PM
  #7026
rmdhawaii's Avatar
The spare FM337 ones that I got are black.
Old 05-27-2006, 09:32 PM
  #7027
rmdhawaii's Avatar
Originally Posted by OVA
I'm useing kit oil...Not over fill...I took out the shims behind the large bevel and much better but the out drive is too loose ..you can pull the out drive in and out ... Dang can't find my instruction
Check out the kit info page at my Web site for the instructions.
Old 05-27-2006, 09:33 PM
  #7028
Racing4Evo's Avatar
The regular and WCE have different pivotballs. I take it you bought your kit as a WC. My first RRR was when it first came out and it had silver pivotballs.
  #7029
Franko, I'm pm'ing you my cell... if you can't figure it out, give me a call.
BTW, I'm 95% sure I won't be up tomorrow, trying to get over this cold.
Dom
Old 05-27-2006, 09:36 PM
  #7030
Yup, the regular kit had FZ74 as pivot balls, and like Rainer posted, FM337 for the WCE kit.
Dom
Old 05-27-2006, 09:37 PM
  #7031
rmdhawaii's Avatar
I check the ones on my car that came with the kit and they are black as well...
I hear you - but if it brakes during a race, that's it. After crashing, I'm always worried that they are bent, but whenever I check them out, they are okay. It's usually the suspension arms that take all the damage.
Old 05-27-2006, 09:43 PM
  #7032
Racing4Evo's Avatar
I've never broken or bent the black ones nor have I ever seen on a sedan or the evolva. There's the chance that the plactic will break but I think that has to be a serious hit to break the car. I guess everything's a tradeoff.
Old 05-27-2006, 09:49 PM
  #7033
rmdhawaii's Avatar
Dom - You have a chance to break in that STI yet?
Old 05-27-2006, 09:54 PM
  #7034
No, Mine is all torn down in parts sitting inside the box. Mike ran his last weekend, the motor is ballistic!!! I ran my last year EVO 3 with the new EVO3 pipe, Mike's motor and his VR12 pipe was still a bit faster at the end of the straight.
Dom
Old 05-27-2006, 09:58 PM
  #7035
OVA
OVA's Avatar
Dom
Hey Dom Thank for your help and rmdhawaii too as well..
OVA is offline
