Kyosho v-one rrr >
Kyosho v-one rrr
Kyosho v-one rrr
Old 01-15-2006, 07:38 PM
  #4711
im just sayin i joined the rrrworlds club and im looking forward to racing in the spring .
up north its to cold but that gives me time to build it right.
i just ordered screwz and am looking at hopups 3racing has some decient one from my knowledge.
this sites also helpful .
one last thing does any one know of tracks in jersey or surrounding states :
donald wilson is offline
Old 01-16-2006, 12:21 AM
  #4712
jas
jas's Avatar
Hi guys, sorry for interrupting. I've got some new in bag Kyosho and Kawahara option parts for the V-One cars for auction at eBay. Please check it out at the link below if you are interested. Thank you for your time.
http://cgi.ebay.com/ws/eBayISAPI.dll...MESE%3AIT&rd=1
jas is offline
Old 01-16-2006, 12:33 AM
  #4713
MCRUZ's Avatar
Smile
Originally Posted by C Verano
Marc,
Congrats on the new ride.
Chris
Thanks guys.
MCRUZ is offline
Old 01-16-2006, 02:47 AM
  #4714
Trader Rating: 15 (94%+)
Default some help with setup
hey guys just wanting to know if i can get some help with set up ?
i am racing on a medium sized track withlots of tight turns and short straights
i guess traction is medium, the trackis the size of 2 tennis courts
my setup front:
+1 toe out, droop set to zero. track set to 199mm
-2.5 camber
front spool
shocks on low position with silver springs
37shore zac tyres
castor clips to the back
sway bar is set to in between flat and horizontal
rear:
toe in -3. track set to 200mm
10000wt diff oil
black springs. droop set to 3 on droop blocks
silver swaybar, camber set to -3
37 shore zac tyre
the car feels to have heaps of steering, very low rear grip and wandery in the straight. the rear end slides out on power. im uisng the os 5 port tz. im actually thinking of going down a tooth on both spur gears.
mrgsr is offline
Old 01-16-2006, 02:49 AM
  #4715
for those in australia i was trying to use that setup in the fairy meadow track wollongong.
i have also lowered the rear roll centre by turning the stock clips around.
the restof the cars setup is standard
mrgsr is offline
Old 01-16-2006, 10:55 AM
  #4716
kewdawg's Avatar
my setup front:
-2.5 camber
front spool
37shore zac tyres
rear:
10000wt diff oil
37 shore zac tyre
Reduce your rear diff oil to 5,000 wt., remove the blue spacer under the camber link and use the softer rear spring (silver). Use the stock rear sway bar (black) and mount the rear shocks in the #3 position. For the front: Use the stock springs (black) for the shocks, in the 2.5 position on the tower. Reduce you front camber to 1.5mm. Use a 60 front / 40 rear split in shock oil wt.. This should plant the rear end and settle down the front end. Good luck!
kewdawg is offline
Old 01-16-2006, 02:27 PM
  #4717
wow thanks for all that
do you mean 60wt front shocks and 40wt rear shocks oil ?
mrgsr is offline
Old 01-16-2006, 02:32 PM
  #4718
kewdawg's Avatar
kewdawg is offline
Old 01-16-2006, 03:09 PM
  #4719
AndyT ©'s Avatar
After chatting with some of the A finalists from the winternats who ran RRR`s....they were running-
Silver front springs
Yellow rear springs
35 wt oil front and rear
Cheers
AndyT © is offline
Old 01-16-2006, 06:06 PM
  #4720
kewdawg's Avatar
Yellow rear springs
Cheers
AndyT,
Did you read his post? He's not running at the Winter Nats. He's got too much steering and not enough rear traction.
kewdawg is offline
Old 01-16-2006, 10:19 PM
  #4721
AndyT ©'s Avatar
He was asking for a setup for Fairy Meadow....the info i posted is what some of the quickest guys in Australia are using at that particular track......it just so happens that the Winternats is the last time they raced there.
AndyT © is offline
Old 01-16-2006, 11:29 PM
  #4722
luketob's Avatar
Originally Posted by MCRUZ
Thanks guys.
Congrats Mark on the new ride, see u at the track!
luketob is offline
Old 01-17-2006, 07:06 AM
  #4723
kewdawg's Avatar
How long ago was that AND what was the rest of their set-up? This is very important info. that you're not including. If, it was last year or a different season (weather change) then the set-up probably isn't usable. Depending on the rest of their set-up, it might not be usable at all. SILVER front springs which are softer than the stock springs and 35 wt. which is also, softer than the stock oil won't help.
kewdawg is offline
Old 01-17-2006, 01:36 PM
  #4724
AndyT ©'s Avatar
That spring/oil setup was run 6 months ago at that track. I agree conditions have changed, but its handy to have something as a guide/reference (thats been used and 'A' finalled on that particular track)to get started and work on an ideal setup from there.
Cheers
AndyT © is offline
Old 01-17-2006, 06:04 PM
  #4725
kewdawg's Avatar
its handy to have something as a guide/reference to get started and work on an ideal setup from there.
This is exactly what I had in mind when I posted my suggestions.
kewdawg is offline
