Kyosho v-one rrr
#3451
Originally Posted by joemugen
i doubt you would get a tan.... just a really really bad sun burn maybe .
#3453
Originally Posted by NiMo
Just found this picture of me (in race control) from a few years back wearing the required winter clothing (including fingerless mittens)
#3454
Here are some shots from a few years back
Schumacher Mini Pins and Shaft Driven cars are the best in these conditions (snow gets in the belts).
#3455
Ozpal. Of course everyone is going to have an opinion on this one. I would say if you just started racing in the last year to stay with the V-one S (not spend too much money upgrading it) until you can drive it faster than it will go. Then there are several cars out there that will perform well. I like the RR Evo because it is a bit stronger than the RRR (My opinion). Good luck and have fun racing.
JEFF
JEFF
#3456
Posted some info on my car set up a few pages back, only to have others tell me it's set up wrong, so I tend to keep it to myself or to those who come to my track.
After all with over 130 trophies (in 12 years) I must be doing something right.
#3457
just purchased my new v-one rrr wce . please help me get the essential things i may need such as hopups,parts that break alot,what rx batt. and anything that i may have forgotten
#3458
I just bought spur gears, pinions, and the optional rear sway bars and spring set. including rear white springs from the 1/8 scale. If you are just gonna race at one area just see which spring set and sway bar the fast guys are using and just buy what is needed. as for replacement parts, I would buy
an extra mainshaft (2spd shaft) and rear hubs.
now on to hop ups. and rx. i like the skyline shock tower, and rx packs. I also bought the muffler stay but the wce already comes with a nice mufler stay so you probably wont need that.
#3459
so really all i need is rear hubs and a 2sp.shft,and the skyline rx pack?
for the sway bars and springs just check at my local races?
#3460
Well if you have a local hobby shop with the parts I wouldn't recommend
loading up on parts. but if parts are hard to come by then
I would buy an extra set of upper/lower bumber set, front arms, rear arms,
and lower hinge pins. I don't know if the wce already comes with the thicker
rear shock tower but if it doesn't i would also pick up the skyline shock tower.
#3461
hello people i just got my 3r and it doesnt turn in sharp corners to the right as sharp as it does to the left can anyone help me
#3462
thanx jwf. i will have stock up on parts cause my hobbyshop don't have ****
whut up kewdawg it's your boy!
#3463
jeffreylin
how do you get the 3r to turn in realy sharp corners what set up should i use
#3464
Depends where youre racing, what type of surface etc...........Where are you racing? Maybe someone can help with a setup.
#3465
