Kyosho v-one rrr
#2821
rear belt
I had busted my rear belt..... the other day and was planning to fix it so i managed to open up the rear and found out that the belt had destroyed the pully aswell...... so had to order the rear pully diff cup and put it all up again.....
there are 3 settings...... tight - normal - loose for the belt...... in the housing.. it is currently set on loose....... i was gonna put it on tight when a freind told me not to--- coz it would eat up the belt.......
what u guys reckon is the perfect - setting........ or commonly used ?
Thanks.
Ziizo
Thanks.
Ziizo
#2822
Originally Posted by jeffreylin
Finally on the droop. I run relative small tires (generally 57/59) and 6-7mm gives plenty of droop. if you run bigger tires you probably need even less (as in 8-9mm). For a simple explaination on effects of droop setting, read the following:
http://www.donegal.flyer.co.uk/car%20setup%20guide.htm
Jeffreylin, may I know what droop are you running in the front? Thanks!
#2823
Originally Posted by TRAJ
Hey Andy im going down there next Sunday for practice....
Have you run on the track yet? Would lighter diff oil in the rear benifit the car there? say 10k?
Cheers
Cheers
I`ve done the past 2 meetings at Fairy Meadow.....i ran the stock oil 30k and it had plenty of steering (even when i ran the solid front diff at the 2nd meeting)......the stock oil should be fine.
Tyres...either 37 or 40 shore are fine....the grip comes up during the day. In the morning theres a fair bit of shade over the track (especially near drivers stand) so the track doesnt have as much grip early in the day, as its surface temp is still quite cool.
A front diff/solid is the way to go (i ran a one-way 1st meet).....you really need the brakes around this track as it has a few short fast sections leading into hairpins.
Cheers
#2824
Originally Posted by Dynamite
hey andy!
Yeh man, sent my entry in last friday
have you tryed the spool yet? i found it to make the front belt heaps too tight, even with it on the loosest setting possible. Anyone else have this problem?
My front belts tension seems okay when running the spool....its not a new belt though, so may have stretched a bit over a new one and runs a bit looser.
#2825
Originally Posted by tiger266
Can you give me the code no e.g. VZ012 for rear diff outdrive, cause the only differential i can find in the option/spare parts in the manual is the Front differential gear. thanks
#2826
Thanks.
Ziizo
Thanks.
Ziizo
#2827
#2828
Originally Posted by NiMo
He's got a problem
#2830
Originally Posted by Rob Phillips
I have once again joined the Kyosho Nation. I just ordered my WC today can't wait to get it. Any need to order the 4mm 3racing Chassis, or anything else? And do I need any special tools for the centax style clutch?
A good caliper is all you need for the centax to start. Tools will make it easier but not necessary.
#2831
Originally Posted by AndyT ©
Hi Daniel
Cheers
Cheers
#2832
#2833
Originally Posted by Grinder
I tried the 4mm chassis and it made the car handle poorly. Soon I will try a 2.5mm chassis
Who does a 2.5mm for the RRR?
#2834
hey guys i'm having an absolute * of a time trying to get the front solid into the car... origionally i didnt put it in because i found the belt too tight and binded up the front of the car so i stuck with the oneway...
now i can get the solid to go in albeit really really tight that it pushes the front bulkheads out a little... but i can get it in there, i found turning the right bearing housing around made it go as easy as the oneway drops in - hoping the housing wont come off when i go to try it...
at least i can get the dang thing in now...
the problems i have now is the ackerman hits the outer rim where the ballcups for steering arms attach, actually hits the ballcup. also the front right cvd sits into the solid perfect but the left cvd sits right at the end and falls out... so i thought what the... stuck the oneway back in... sits in the same distance both sides...
so although i am hanging out to try a solid in the front! i just cant seem to make it work in getting it to go in functionally!!! ARRGH!!
has anybody else had these problems? or found some solutions? (i got the recomended front drives too so they cant be too small)
#2835
I had no problem in fitting the diff housing, and I used the #11 ackerman.
