GRP engine glowplug >
GRP engine glowplug
GRP engine glowplug
Old 11-07-2010, 08:18 AM
Fluke's Avatar
Default GRP engine glowplug
hi guys, i need some help
what turbo glow plugs besides GRP will fit a GRP touring tuned .21 engine please
Fluke is offline
Old 11-08-2010, 12:09 AM
OS, O'Donnell and other plugs will work fine. I dont think Novarossi plugs would be so well.
DJ_Shakespear is offline
Old 11-08-2010, 06:05 AM
Fluke's Avatar
thanks
o'donnell doesn't work but will try OS
what would you gys recommend for a .12 with 16% nitro?
Fluke is offline
Old 11-08-2010, 06:12 AM
teamlosi906's Avatar
Trader Rating: 235 (100%+)
Default plug
I used oddonel in my offroad grp worked great. os plugs the taper is different,once used you have to stick with it. off road anyways,should be the same .
teamlosi906 is offline
Old 11-08-2010, 06:16 AM
wingracer's Avatar
Trader Rating: 24 (100%+)
Technopower plugs should be a direct fit. A #6 should do the job. Maybe a 7 since they say their plugs are hotter than the original GRPs.
wingracer is offline
Old 11-08-2010, 06:20 AM
wingracer's Avatar
http://www.amainhobbies.com/index.ph...filter_mfr=731
Old 11-08-2010, 06:30 AM
mugenize1's Avatar
I have Mugen ninja plugs $7.00 each I think I have 3 of them and 1 I use to start an engine put one tank then pulled the glow plug out. #6 Plug
mugenize1 is offline
Old 11-08-2010, 08:37 AM
mugenize1's Avatar
I also have a GRP with a ninja crank shaft and sleeve in it has 1 Gallon on it do not need the engine anymore move to 1/10 scale I need a .12 engine so selling to get one.
Old 11-08-2010, 08:59 AM
Fluke's Avatar
thanks for the response
well the o'donnel plug plug doesn't seal the engine well and grp plugs are hard to come by nowadays
Fluke is offline
Old 11-08-2010, 09:25 AM
Roelof's Avatar
GRP has started up their production again and is selling plugs, as with their tires you should be able to get them directly from them.
There are also some other brands selling GRP plugs under their brandname, I know MAX has them.
Roelof is offline
Old 11-08-2010, 09:30 AM
wingracer's Avatar
Yep, Maxpower genII, technopower, TQ alpha, etc.
Old 11-08-2010, 09:59 AM
Team Kamikaze's Avatar
All I can say is that none of the current plugs are as good as the original "Ninja" Plugs.
Team Kamikaze is offline
Old 11-08-2010, 10:16 AM
Roelof's Avatar
The last batch GRP plugs which hitted the market during/after the fire of their factory were rubbish. A friend had bought the new production plugs and they seem to be working the same as the old Ninja.
We are switched over to Merlin Glowplugs and have no issues with them, they give a good response, do not get damaged easily and also the price is right (when buying voor 2000 dollar of plugs)
Roelof is offline
Old 11-08-2010, 10:33 AM
nytaurean's Avatar
Default GRP Plugs
I purchased 30 GRP Plugs from The Border online last season and they are absolute garbage. They seam to be GRP Fakes. They came in zip lock bags unlike the original GRP plastic cases all the plugs usually come in. They do not last and will lose the filament and scratch your piston up very badly.
I contacted The Border about the authenticity of these plugs and of course they denied it, but please do yourself a favor and only purchase these plugs from someone you can trust.
nytaurean is offline
Old 11-08-2010, 11:23 AM
mugenize1's Avatar
Thats what I have #6 Plug
