MUGEN SEIKI MRX5 >
MUGEN SEIKI MRX5
Like Tree3Likes
MUGEN SEIKI MRX5
Old 04-01-2011, 03:33 PM
  #1876
ralphierace13's Avatar
Originally Posted by Vector03cobra
grind it down from the front......from the front does nothing.... The problem is the amount of cone htat was sticking out of the rear.
With a NR flash it comes with 2 cones the 5.5 cone i used and did the following
Here is the difference a 5.5 cone has the same Dia as a 7 at the rear, and the same at the front the problem is always at the rear in this case.
I took the 5.5 cone down to 5.0, works fine its just a PITA to do.
Thanks for the info, tips and help.
I used the following Fly wheels and got the following gap between motor and flywheel on a stock 5.5 cone
Mugen 1.17
Arrow max 1.20
Prior to sanding thats the best I could get.
With the cone at 5.0 I can shim the clutch anyway I like
Here is some pics, The pics are messy but I am working away at things so, I like it busy
what flywheel r u using it dont look right?
ralphierace13 is offline
Old 04-02-2011, 07:57 AM
  #1877
CanyonCarverR1's Avatar
That doesn't look like the Mugen clutch bell either. Have you tried all the stock parts?
CanyonCarverR1 is offline
Old 04-02-2011, 08:03 AM
  #1878
2strokin's Avatar
woah
2strokin is offline
Old 04-02-2011, 09:32 AM
  #1879
Its says in the post you quoted. right in the middle of the post.
I also gave a measurement of all the stock parts used vs a arrowmax part.
The measurement I posted was the distance from the motor to the back edge of the flywheel.
With a 5.5 cone and all stock mugen parts....from the post you qouted
"""I used the following Fly wheels and got the following gap between motor and flywheel on a stock 5.5 cone
Mugen 1.17
Arrow max 1.20"""
I took off .5 off the back of the cone and was able to assembly everything with the mugen parts. After I did that, I took it all back apart and assemblyed it with a Arrowmax fly wheel and a CSO aluminum Bell, no change same settings.
As far as I can tell most of you must use a different cone. I tried 3 different cones the only ones i have. a 5.5 a 7 and one that was 5.5 but looked a little different.
None of them got be down to .75 or lesson the gap between the flywheel and motor.
I also tried 2 mugen fly wheels and 2 arrowmax, no change.
Problem solved I will just turn down the the cone's from now to 5.0 in the future if i have problems.
Vector03cobra is offline
Old 04-02-2011, 10:06 AM
  #1880
Did you try the stock clutch bell? It just seems very strange that you would have to modify anything to get it to fit.
Old 04-02-2011, 10:24 AM
  #1881
Hello guys,
car is awesome i love to drive 1/8th scale again,
i have one major question:
What trackwide (with weels) are u useing (frond and rear) most of the time, i think mine is very wrong.
greetings
thilo-alexander is offline
Old 04-02-2011, 05:11 PM
  #1882
Yes, and that end never seens to make a difference.
I have 3 stock clutch setups and i have 2 setups that use aftermarket parts.
The clutch itself and the parts dont seem to be the problem.
its the cone
Also mugen does not give you a cone with the kit, not in the 2 kits I have.
Some people said they use teh mugen cone, well thats nice and all but its not in the kit.
The assembly of the clutch using stock parts with a stock 5.5 Novarossi cone akk ended up the same way, With the Incert that goes into the end of the bell the part with the trust bearing on it never bottoming out, when it does nto bottom out it locks up the thrust bearing and it also was putting the bell right into the clutch disk
As soon as i removed .5 from the back side of the cone it all went together
I would like to note a friend ran into the same problem.
CanyonCarverR1 What cone did you use?? Brand, Size, ect any info?
Old 04-02-2011, 05:29 PM
  #1883
choisan's Avatar
Originally Posted by Arahawak
Anybody know if there are aftermarket fixed front axle shafts that screws on the wheels instead of the quick release type that fits the MRX5?
hirofactory japan gets it from mrx3, but it is heavy
choisan is offline
Old 04-02-2011, 06:59 PM
  #1884
Default Awesome
I bought this car toy earlier. Its really a gud toy for kids. U can see this on above picture was look awesome i really like this type of toys. You can over there...guys
indiacwc2011 is offline
Old 04-02-2011, 07:01 PM
  #1885
Default Reply
Nice talk
Old 04-02-2011, 07:30 PM
  #1886
its the cone
I think the ones I use came on the Novarossi engines, but I'm not sure. Next time I pull it apart I'll take some measurements if you want.
Old 04-02-2011, 08:05 PM
  #1887
Ok, there had been some others listed in this thread when i first asked about it.
Different then the ones that came with the motor.
Old 04-02-2011, 08:35 PM
  #1888
i have always used the cones that come with the motor, i have never never ran into that kind of problem trust me there something u are doing wrong its hard to see from the pics unless u take a step by step pic, and i never heard of this prob from anyone i race with. i have seen some cones only give u a .8 gap with no shims behind the thrust bearing but never no gap. the best cone that will bring the flywheel closest to the motor is the kyosho. are u putting the spacer that comes with the motors behind the cone?
Old 04-02-2011, 08:40 PM
  #1889
Bill Wyatt's Avatar
Originally Posted by thilo-alexander
Hello guys,
greetings
253mm in the front and 263 in the rear.
http://www.mugenseiki.com/images/mrx...-us1001kit.pdf
Bill Wyatt is offline
Old 04-02-2011, 09:03 PM
  #1890
No spacer behind the cone if i did it would really push things out much farther.
I will check into the kyosha cone see what it is.
Really no mystery to putting it together. I place the cone on the crank Slide it all the way to the back flush with the bearing.place the fly wheel on. and then put on the fly wheel nut.
Then i tighten down the nut, and I now check the gap between flywheel and motor. A fellow form member posted that he was around .6-.65 or something like that, so if its over 1.0 there is no need to go any farther, but if you do as you put it together you would run into the part the bearings and thrust bearing ride on, this part will not come into contact with the tip of the crank.
And if it does not come into contact it will bind the thrust bearing and also because everything is pushed out the bell comes into contact with the disk.
The best info i have got on this so far is knowing the measurement of some other racers gap between the motor and the clutch flywheel.
And also finding out there are some other cones out there that people have used.
With a proper size cone the setup of the clutch is simple
