Capricorn LAB-C01
#826
From reading your post so far it seems like this car is too advance for you hobby knowledge. Take your time with the building process. Yes you will need a starter box. A pull start engine would be difficult to fit into this car as it's a full out race chassis. Loctite should be used but very little on the screws that are going into metal. Blue loctite as the red liquid is too strong. This is an advance race kit. So take your time. Best of luck. And as always we're here to help with your questions.
#827
bah, i am lost. i can't find the recommended engine.
I am looking here
http://www.racing-cars.com/scp/Manufacturer/search.asp
can someone please show me what engine will do and what other accessories i will need? in the mean time, i will go find me a start box
I am looking here
#828
ooooh those are cheap too
thanks so much!
thanks so much!
#831
yea, i found out about schumacher a few days ago. i will definitely order from them. i am trying to make a list of parts i will need first. i am still kinda lost.
for starters i don't even have loctite yet and i don't know if it will be needed. i also don't know what filters to buy and what exhaust. things are starting to get a bit complicated
so do i need a fuel filter? and what size engines are compatible with 1/10 nitro chassis?
Ok here it goes, everything you will need:
Engine, Exhaust and accessories:
Novarossi N12T1 (same as jas1 showed
Novarossi 2601 exhaust with a short header
Fuel filter isn't necessary as there is already one in the tank.
Air filter, the Xceed INS box with filter http://www.xceedrc.com/product/103009
Starterbox, I have the LRP one and it's very good. But if I had to buy one right now I would go for the Hudy box.
http://www.hudy.net/xhudy/products/p...&kategoria=282
You will need two 7.2V Nimh stickpacks for the starterbox or one 4S lipo.
Glowstarter, isn't a specific brand I would recommend, they all seem to do their job.
http://www.xceedrc.com/product/105208
Fuel bottle: http://www.capricornrc.com/capricorn...d_product=1272
And some fuel off course, don't know which brands are available in the UK but I would recommend Runnertime or Capricorn fuel since those are the best.
Other
Loctite, I would recommend Loctite 248, makes for easy application.
Receiver battery, Nimh or Life.
Nimh http://teamorion.com/marathon-1700-r...20-awg-en.html
Wire extension for the batter connection: http://www.electricwingman.com/produ...x?product=1426
Glow plug wrench, to place and remove glowplugs and tightening the flywheel nut: http://www.hudy.net/xhudy/products/p...&kategoria=538
Camber gauge, so you can set the camber on your wheels: http://www.xceedrc.com/product/103033
If you don't have them a set of calipers and a steel ruler.
Some double sided tape to mount the battery and receiver.
Glue for the brakepads, the kind of glue which you apply to both surfaces and bond them together after the glue has dried for 15 minutes.
Only able to find dutch sites: http://www.bison.nl/NL/nl/view.do?UI...c2c7dd2dc07ba0
-1.5 2.0 2.5 3.0 hex wrenches
-4.5 5.0 7.0 nut wrenches
-Some sidecutters and pliers
-Grease for the driveshafts and clutch bearing: http://www.capricornrc.com/capricorn...d_product=1178
If you want a painted body already trimmed for the Lab I could send you this one since I won't be using it, never been run:
When interested contact me by PM.
I'm not sure if this list is complete but it should get you started.
#832
After owning my new capricorn for 3 month thought i would jump in and say hi.
I have been reading your posts and they have been a great help in setting up the car.
Here is my car
Here is my car
#833
awesome info!! thanks for the help.
will contact you about the body shell when i got the car ready
I have been going on a shopping spree with these things lately and now i realised that i put a nice dent in my credit card account. I will wait until next month before i buy any more. I have spent over £2k in just 3 weeks on these things!!
May sound like a stupid question but can I use normal rubber tires on the C01? Something like 26mm wide slicks that I have bought for my 1/10 electric?
#834
Foams are the way to go 26mm fronts and 30mm rears
I use the Capricorn tyres
#835
for the sake of knowledge and learning, will this fit the car?
http://www.capricornrc.com/capricorn...d_product=1193
I don't really plan on buying this but capricorn is quite spartan when it comes to specs (to say the least). Is this a .12 engine? They say it is based on novarossi, but is it a roaring lion or a purring kitty?
#836
Perhaps this link could help you to find out how engine sizes are measured: http://chickentrading.com/viewtopic....9&p=1459#p1459
Kindest regards,
Lars.
#837
yea, the thing is that this is my first car ever so i am not exactly prepared for a very fast engine.
#838
Kindest regards,
Lars.
#839
Ahhh George.. It's you!!! Wondered who Muggin was, what sort of of good greek name is that? Can I send you the copies for the club's DVD.. Address?
#840
