Capricorn LAB-C01
#781
Congrats to Rino Lino 1st at Fort Myers!
Jr
Jr
#782
Shock damping question:
500 cst with 2 holes is similar to XXX cst with 3 holes ???
XXX = ?
XXX = ?
#784
Sure??? !
You answered very quickly...
And 500 cst with 3 holes is similar ... with 2 holes?
#785
But 400 is thinner than 500, right?
So more holes you need thiker to get the same action, no?
#787
seems I am the first one to receive the new version of the C01.
Check out my newbie's second car thread for more details.
#790
Got some of the latest parts to start building my car for the 2011 season.
First the magnesium two-speed bulkheads.
These make the car even lighter and raise the rear ARB assembly so the small clips on the outside aren't needed anymore.
They come with delrin bearing inserts and new bearings.
Then we have the new aluminum downstop brackets. Some have experienced inregular downstop settings caused by pitting on the wishbone's downstop brackets, especially with the soft plastics.
To have perfect downstop settings all the time Capricorn came up with these aluminum brackets. They feature a steel insert where they hit the downstop screw.
The flanged uniballs prevent the link to pop off during a hard crash.
To add weight to the very light car Capricorn has a very heavy motormount.
It's made out of beryllium which is a very heavy and hard material. With this mount you won't strip the threads as with the brass mounts made by other companies. It also moves the entire engine 0.5mm towards the left for better balancing.
Updated chassis which now features mounting holes for balancing weights between the battery and the exhaust. It also has a clutch preload nut adjusting hole which makes adjusting the clutch a lot easier with the engine still in the car.
Still some building to do, basically waiting on some red aluminium screws and washers I've ordered. I'm also redoing all the electronics with lightweight 26 or 32AWG mil. spec wiring.
#792
looks amazing!! am i getting all those upgrades in the box with the limited edition? i am still not sure about what the email said.
your order has been shipped yesterday
you will receive the new version of Lab C01 and you are the first one
we wil release a new versione " European Chanpion limited edition 2010" with some new parts as
pulley kevlar kit
front sway bar kit
bumper plate and lateral brace in plastic
new red shock spring
they say i will receive the new version. but then they say they will release a new version. do they mean i will receive the version they havent released yet? or are they trying to say that i will be getting a new version that is compatible with the upgrade parts from the unreleased version?
pulley kevlar kit
front sway bar kit
#793
pulley kevlar kit
front sway bar kit
pulley kevlar kit
front sway bar kit
From what you've quoted I'm pretty sure you will get the limited edition kit.
It comes with the following parts:
-Kevlar pulley set
-Plasic bumper plate and plastic lateral brace, instead of carbon part (more flex)
-Front sway bar kit
-Long life belt
-Red shock springs (Softer springs)
#794
Cool!
Aren't sway bars standard for front and rear? What's so special about them in the limited edition?
Oh and in the battery holder what size battery can I fit? are there special packs or will my NiMH 6 cell fit?
