Capricorn LAB-C01
#2012
Will the big bore low profile shocks use the same springs?
#2013
#2014
Does the LAB C02 clutch fit on an NT1 car?
How about the 2 speed gears?
thanks
thanks
#2016
#2017
#2018
Finished my custom receiver box:
Need to make some small changes to the design (too thin in some spots) but the overall fit and finish is very nice. The 471 receiver from Sanwa fits perfectly.
Now that I know the minium wall thickness and design features of the material I will start with the design of the universal receiver box for the standard Capricorn cars.
#2020
Because I have a c02 and am wondering what parts I can use on an nt1. I looked at the diagram that shows the interchangeable parts for the two cars but I don't think it explains if you can substitute the clutch or two speed etc.
#2021
If you measure the OD difference in spurs 1st and 2nd and compare to the OD split of pinion, then it should mesh. But then your gear ratios may be way out, so check if the pinions are interchangeable.
#2022
#2023
15t kyosho steel pinion
Should be VZW215-15 But keep in mind that 15t is steel! Going to last forever, but I'm sure it will affect spool up and acceleration! I have one but I haven't used it yet, it's like 5xs heavier than the aluminum cap pinion!!
#2025
Nice car is nice!!
