European 2wd 1/8th pan car on-road Classic class
#4323
Rick, yeah I was not sure maybe its an early pre-release? As its between the rear bulkhead? But I think they played it smart using the C8S front end.
EDIT: Appears the Chassis is too...
Rody even has the BL version listed on WCP too 🤘
the event, looks so awesome, I am going to have to make an effort to go next year!!! Even if I am a back marker, lol
https://boerimodelisme.fr/divers/1er...70UrG2Pa1hjsTg
#4324
[QUOTE=1/8 IC Fan;15322841]So as a warning, if you like or want to buy Delta Plastik bodies, and think to get a heavier 1mm body... its not!
The material may have started somewhere at 1mm...
My Delta Plastics body was the same way the listing stated 1mm but it's 1.5mm and had the 1.5mm sticker on it. Yeah I was upset. Parma will be my next body.
#4325
Last year they tried to modify the rules and lower the weight of the cars, but this has been rejected because beside the official brands there are also quite a lot of cars designed and made by racers themselves and not using excotical materials.
So a way to keep the costs limited in this area.
#4326
The same they needed to do with the normal 1/8 cars. Most cars in a normal configuration are still 2450 up to 2500 gram but todays limit is 2350 because racers do use all kind of exotic materials. Even last EFRS AGM there was a proposal to set the limit lower, prrrrffff.....
#4328
#4330
#4331
#4333
MB Proto italy
own design arms, from 3D moulded proto
#4334
